Question about HP L1702 17" LCD Monitor
I have three of these HP 1702's that all flicker on but then go off. Then they'll flash back on for a second and turn off again. I opened one up and looked for bad caps using http://s807.photobucket.com/albums/yy352/budm/HP%201702/ as a guide. I discovered two of the 470uf capacitors to be obviously "domed" so I replaced them with new 470's I bought at RadioShack. I put it back together and hooked it up to a computer and found that it is still flashing on and off. The other caps all apear normal to me. They are neither bulging on the top or the bottom. What should I do next?
  • 11,361 Answers
You should replace them as a set as I show in the pictures (all the one by the heat sink and the one by small blue caps, 6 total), those that did have domed top were checked bad because they have high ESR (Equivalent Series Resistance). If you use standard caps from Radio Shack they may not last since they are not low ESR type. I use PANASONIC FM or FC series from Digikey. You also need to check those 4 transistors by the small blue caps since when the DC filter caps went bad it can take out the transistors also. http://s807.photobucket.com/albums/yy352/budm/HP%201702/?action=view&current=DSCF2053.jpg
I hope he monitor does have bad lamp assemblies also.
Posted on Jul 04, 2010
Testimonial: "I replaced the 6 caps Budmrtn recommended and the monitor works flawlessly now!"
  • eckertb Dec 21, 2010
    I've got the same monitor but my power inverter board looks nothing like the one in the links. I replaced the 2-470uf 16v caps an 3 - 1000uf 16v I could find any 16v so I used 35v. But in my search for the transistors I couldn't find locate them on the board. So I put everything back together and its still doing thing of turning on for a few seconds then turns out. Any other help would be great. Thanks.
  • mdpetteys Mar 05, 2011
    Hey Joel G. I have a working 1702 with bad cable, got a spare internal VGA?
    Mike
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
Jul 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Hp officejet 8600 pro LED display flickers
This model has screen errors. You will need to exchange printer or change the screen on printer. Removes with three screws on top of the screen latch.
Jun 17, 2017 | HP OfficeJet Office Equipment & Supplies
White screen display just a seconds it will turn off immediately.
Software flashing can help you so contact mobile tech or follow the instruction belowFirst download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 18, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Engin light is on how to check codes
To check for trouble codes turn the ignition switch to run for three seconds (one second pause after the fuel pump stops running) and then turn the switch back to off for three seconds. Repeat this process again. Now turn the switch to ignition and wait for about 8 seconds and the check engine lamp will start flashing the codes. If there are codes present the light will flash rapidly (about three per second) then there will be a 2 second pause with the lamp off. The lamp will then flash one or more times to indicate the first digit of the trouble code. It will be on and off for about 1 second. Count the number of times it flashes for the first digit of the trouble code. Then there will be about a 2 second delay then will flash again for the second digit. After flashing the second digit there will be a 2 second delay and additional trouble codes will be flashed. Write down the numbers and when they start repeating themselves the trouble code transmission is completed. All trouble codes consist of two digits.
If the lamp flashes only the 3 flashes per second there are no trouble codes present.
If there are codes present, let me know and I can advise you of their meaning.
Oct 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
HP 1702 Monitor comes on but immediately goes off.
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Mar 23, 2009 | Computers & Internet
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Jan 08, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP L1702 17" LCD Monitor Logo
941 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
