Question about Precor 933 Premium Series Treadmill
Circuit breaker trips
Anytime my 9.33M (made circa 2004) accelerates too quickly the power trips off, for example if I'm walking at 3.5 and hold the speed up to 6.0, the acceleration curve sucks the amps and trips the power. The same happens if it's at a steady state of 7.0 or more and I get on it, like my weight adds to the amperage load and then that trips it. Then I have to manually turn the floor level power switch on again. I figure it's either a power supply breaker or a digital board breaker, but I won't know by visual inspection. Because it functions when I flip it back on I don't think it's a blown fuse, for example. But it makes the machine almost useless. BTW, it worked fine up until about the past year. Thanks.
  • Precor Master
  • 914 Answers
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
http://www.sportsmith.net/productsearch.aspx?dsNav=N:11884&sc=product
Posted on Jan 26, 2015
5 Suggested Answers
  • 42 Answers
SOURCE: treadmill will run for about
HI, are you using an extention wire, if you are then please unroll the whole wire, another thing is you can try to put a higher amp in the plug. if after this you are still having the same problem then there is something wrong in the circuit pannel.
Posted on Nov 16, 2010
  • 42 Answers
SOURCE: The circuit breaker trips when i get over about
hi, firstly if you are using a extention wire unroll the whole thing, and putting a higher amp volt in the plug. this should help
Posted on Nov 21, 2010
SOURCE: After walking for 10 minutes or so, or even sooner
Check your Amps on the circuit that is being tripped. The treadmill needs 15 Amps to run. If you have a 15 Amp circuit that is running the treadmill and other electronics (or lights), the circuit will trip. You may need to replace the circuit with more Amps.
Posted on Mar 03, 2011
ercupa190
  • 12223 Answers
SOURCE: My precor 956i sets the reset button off after 20 mins of use. It is on its own 20 amp circit.Sometimes it shuts off sooner
You have mixed problems: mechanical-electical-electronics
I am giving a combo for solutions Watch the videos-tips for mechanical adjustments firts:
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
http://www.youtube.com/watch?v=dxpOOPetVLo
If the problem persist, go to the 2nd phase:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
After this adjustments, if the problem persist you will be Strong conclusion: 1) Transformer Faulty, 2) Speed SENSOR 3) Main Motor 4) PController Motor Board, Since PCB controls 90-95% functions of the treadmills. sincerely.
Posted on Nov 21, 2011
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
Volvo Penta Marine engine 5.0 GXI 2004
there should be some loose connection or short circut, that is the only thing that can cause it.
Sep 23, 2008 | 2004 Volvo V50
We're is the fuse on the Jet 3
I hope this helps:
The main circuit breaker is located on the front of the battery tray.
Main Circuit Breaker: The main circuit breaker is a safety feature built into your power chair. When the batteries and the motors are heavily strained (e.g., from excessive loads), the main circuit breaker trips to prevent damage to the motors and the electronics. If the circuit trips, allow your power chair to "rest" for approximately one minute. Next, push in the circuit breaker button, turn on the controller, and continue normal operation. If the main circuit breaker continues to trip repeat- edly, contact your authorized Pride Provider.
Here is a link to the owners manual too:
http://www.spinlife.com/files/pride_jet_3_ultra_om.pdf
Jan 31, 2013 | Health & Beauty
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
    your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
    Jun 19, 2010 | GE JVM1441 Microwave Oven
    Malibu Lighting Breaker Switch
    There are two possible problems you could be facing (excluding the transformer going bad) If you have replaced light bulbs with higher wattage ones, you could be drawing too much current through the transformer. (It is common for MR-16 style lightbulbs to be 20w in landscape lights, but 50w for inside lights, and the local hardware store usually only carries the 50w replacement lamps) Each transformer has a specific amount of "watts" it can supply (anywhere from 100w to 1000w) If you exceed the supply wattage of the transformer, the breaker inside the transformer will trip. The quick and easy way to test this is to take a few of the lightbulbs out and see if the breaker will hold.
    If you are positive that the total lamp wattage does not exceed the rating of the transformer the second possible problem (but less likely) is that you have a lamp socket or wire connection that is full of water. This water between the two conductors draws current just like a light bulb and can cause an overcurrent fault. This is usually more common if it starts to trip right after a heavy rain when the ground gets saturated with water.
    Good Luck!
    Jan 20, 2010 | Malibu Intermatic Inc. ML121RT Low...
    3-pole 60 Amp Circuit Breaker is tripped and won't reset.
    When this breaker tripped, it did not go fully to off. Push the breaker all the way off and then all the way to on. It should be fine. If not manually push it to full off once again and then back on. If both attempts fail the breaker will have to be replaced. good luck.
    Jan 25, 2009 | RTO Cutler-hammergd3100 100amp 3pole...
    Precor 933 Premium Series Treadmill Logo
    339 people viewed this question
    Top Precor Exercise & Fitness Experts
    Sportsmith LLC
    Sportsmith LLC
    Electro Med Services...
    Shehu Pro
    Shehu Pro
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
