Question about Daewoo Heating & Cooling
Can DAEWOO 0520RLE Air Conditioner be installed through the wall?
My husband and I are considering the purchase of a DAEWOO DWC-0520RLE Air Conditioner, which is on sale at Costco.
We want to use it as a through-the-wall unit rather than a window unit.
Is this doable? If so, do you have any instructions that you can supply and/or parts that you can recommend to accomplish this?
Also, are there problems that we might run into by installing it as a wall unit? Again, if so, do you have any recommendations on what we might be able to do to avoid them?
Thanks for whatever feedback you can supply!
  • 1,284 Answers
Hi, the DAEWOO DWC-0520RLE Air Conditioner was actually built as a window unit and it would be a risk using it as a through-the-wall unit except you have a tech around you who can do the installation because he would be in a better position to tell you the needed parts to accomplish it.
Take care
Posted on Jul 03, 2010
I have a Daewoo DWC-0520rle air conditioner and the remote does not work. Put in new batteries and still nothing happens. I live in Hawaii is there any place here that I can get a new remote?
Before you shop for a new remote, check the installation of the batteries. It's quite easy to make a mistake with the placement while replacing batteries.
Aug 24, 2013 | Daewoo DWC-052C Air Conditioner
My daewoo air conditioner model: Dwc-0520rle stinks when i turn it on , why ?
could be something dead in the casing and also check the filter is clean
Sep 15, 2011 | Vacuums
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
My air conditioner Daewoo DWC-100R keeps tripping the switch on power bar ... I just purchased it second hand and was assured it was in perfect working order. I am 65 yrs. old female with no knowledge of...
Have you tried to plug it directly into the wall Maybe the the power strip you are using is not able to handle the amps needed to run air cond. If thats not it you have a short to ground that needs to be checked out.
Jul 12, 2010 | Daewoo DWC-100R Air Conditioner
I purchased 2 0520RLE airconditioners at cosco one has no hardwar
Contact the manufacturer explain your problem and they should send you the hardware you require.
Jun 12, 2010 | Daewoo DWC-052C Air Conditioner
Clicking noises can be heard from my new Daewoo dwc-0520rle Air Conditioner when its running. Is there a way to fix this?
make sure thisis abnormal because sme a/c are noisy in operaqtion but if not check mat fan motor bearing need lubrication or replacement
note if still in waranty let dealer check
Sep 04, 2009 | Daewoo DWC-052C Air Conditioner
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Daewoo (DWC-056CL) Air Conditioner
You don't have to remove the polystyrene that is inside the unit. It is part of the construction of the unit. It is part of the molded construction.
Jul 02, 2008 | Daewoo DWC-056CL Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
