Question about Dryers
LG DLE5977W will not turn on when plugged in
When I plug in the dryer, it just won't turn on
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerLG DLE5977W will not turn on when plugged in - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningDryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 04, 2010
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
I have a lg dle5977w is the dry light supost to flash when it's runing?
You would find this answer in the owners manual. Or call LG suppliers in your area for leads to the LG 'technical help Line.'
Oct 18, 2013 | LG DLE5977 Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Dryer DLE5977W washer WM2277HW just bought used ones no operating manuals help need one for each piece where do i get them
Follow the links below with Internet Explorer ONLY, opening these files may require the free download of additional software for viewing:
WM2277W Then Click on English Manual
DLE5977W Then Click on English Manual
Aug 28, 2009 | LG DLE5977 Electric Dryer
ELECTRIC XL LOAD CAP DLE5977W
You gave me the best info to let my repair man know the problem. I cannot get to the belt and have been told it is a pretty big job and my dryer is still under warranty..so they are fixing it for me this week. Thank you for the information, it was helpful.
May 02, 2009 | LG Dryers
My LG DLE5977W electrical dryer won't heat
bad thermostats or heat element broken
Feb 24, 2009 | LG DLE5977 Electric Dryer
Install dryer belt on a lg
You will need to remove the front panel and the front drum support to get to the belt.
Mar 24, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
