Question about Haier HWR06XC7 Air Conditioner
I plugged the unit in and it beeps once and shuts off. I hit the test button wait for a few seconds and try it again. Nothing happens. I hold a few buttons and get and E1. Please help me it's getting really muggy out.
KOakaKO
  • 135 Answers
SOURCE: Haier wall-unit AC wont work
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in. This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine! Couldn't hurt to try it out. ;)
Posted on Aug 04, 2007
SOURCE: haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Posted on Mar 31, 2008
  • 1257 Answers
SOURCE: E1 error code
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
  • 330 Answers
SOURCE: Error code
Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
Posted on Jul 03, 2008
roniecon
  • 6927 Answers
SOURCE: haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Posted on Jul 03, 2009
Overload message on my janome 8000
I know you said you have performed the reset sequence, but try these steps and see if the unit goes through the diagnostics correctly.
  • Turn off your Janome MC8000. Wait for a few seconds.
  • Press and hold the "Start," "Reverse" and "Auto lock" buttons at the same time.
  • Release the three buttons once your Janome MC8000 turns on.
  • Locate the plus (+) sign on the machine screen. Press the plus sign when prompted. Wait till you receive a message that says "Test Complete."
5
  • Turn off the Janome MC8000. Wait for a few seconds.
6
  • Turn on the Janome MC8000 once again. This will prompt the embroidery machine to conduct a diagnosis. Wait till it finishes the diagnosis and troubleshoots the errors you were encountering before.
Nov 10, 2013 | Janome Memory Craft 5700
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
My Sony PS3 is the orginal 60 GB unit and worked fine for quite a few years until the icon stopped appearing. This meant I could play blue ray, CD, DVDs. I had no problem playing a game that was on the...
You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Ps3 dead after firmware upgrade
You are going to have to upgrade the firmware manually..download it with your computer to a external hard drive.from the playstation website...then plug it in to your ps3.. it should upgrade automatically..
then if you say nothing happens you mean like black out??
if so then try doing this recovery boot.
Access the PS3 recovery menu
1. Turn off Playstation2.gif®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Please let me know if i helped you at all please vote.. thank you
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
Expandable handset will not register
It sounds like the base unit has other handsets registered to it. This is why you are getting the message "All Handsets Registered". You will need to reset the base unit in order to register your two handsets.
Hopefully this will help you. Put the phone in an easily accessible spot where you can plug it in and unplug it easily. Unplug the phone, wait a few seconds, and plug it in again. Now, unplug it again, and before you plug it in once more, hold down the Locator button as you plug it in and all lights should flash on. It should emit a long beep, which means it has reset. If not, you will need to unplug it once more and hold down the Locator button again as you plug it in.
Once it beeps, it should allow you to add your handsets. If there is nothing on the handset display, press the off button, menu, then 001. It should then read "Press LOCATOR on base for 3 sec, Then press ok". At this point, you will need to hold down the Locator button until it flashes before hitting okay. The handset will be registered when it reads "Handset 1 Registered".
If this doesn't work, I would call Panasonic.
Good Luck!
~Julia
Jun 04, 2009 | Panasonic KX-TG6071M Cordless Phone
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
HP Laptop
Try this,
Unplug the laptop, remove the battery from the underside (there should be a catch to push, and the battery will pop out). Then wait a few seconds and put the the power cord back in and the battery. Hold down the on button for a few seconds and boot it up.
May 22, 2008 | Computers & Internet
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Haier HWR06XC7 Air Conditioner Logo
82 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
