Question about Garden
Ryobi RY26500 Gas Trimmer How do you put trottle handle back together. Has two springs inside. Parts manual only showing one. This is item 32. Not sure where other spring goes Can you help? Wayne
  • Waynew05 Jul 03, 2010
    yes
  • Waynew05 Jul 04, 2010
    thanks for your help. Back together and running
    Wayne
  • 2,335 Answers
When I look at the exploded diagram of the Ryobi RY26500 Gas Trimmer (figure A), I can see that there is a spring for the trigger, and a compression spring inside the shaft. Obviously, these two springs are quite different, and you would not have any difficulty telling them apart, or mistaking them for each other. If you are looking at two identical springs, then I am wondering if your unit came with two springs in the one location, either as an assembly mistake or to provide 'double springiness' in the trigger.
Otherwise, I wonder how much of a teardown you have performed on your trimmer: there is a spring in part 9, figure B, and also in figure C part 9.
I hope that helps.
_______________________________________________
Ryobi RY26500 Gas Trimmer Parts Manual Download
I hope that helps.
________________________________________________
Download Ryobi RY26500 Gas Trimmer Parts Manual
Posted on Jul 03, 2010
    Pabloloco
    Thanks for your reply. When I took throttle case apart, there where two springs inside.Item
    32 and some other spring. Parts only shows item 32. I know about the other spring that you are talking about that is compression spring. That spring is in shaft arm.
    Not sure what the other spring is for that was in throttle case.
    What steps do I take to reassemble throttle case?
    Wayne
What is the proper configuration of the ryobi p2200 string trimmer head assembly?
Ryobi P2200 18 Volt Hybird String Trimmer Parts
Find Part By Symptom on right side
Select "Trimmer line feeds too much / continuous"
Will show you list of parts to hopefully fix you problem
Jul 22, 2017 | Ryobi Garden
Tip
Would you like a digital, searchable, pdf version of the Ryobi RY26500 Gas Trimmer Parts Manual?
Follow this link (& click FREE) to download a pdf version of the Ryobi RY26500 Gas Trimmer Parts Manual.
I hope that helps.
on Jul 03, 2010 | Garden
Ryobi TSS100L blade guard spring
I think what you are refering to is a circlip washer , and can only be
fitted with ( CIRCLIP PLIERS ) do you know any Michanics or Engineers as they are bound to have a set in their toolbox ,on the other hand you
can buy them. What they do is work in the opposit way normal pliers do
when you squees the handles together the jaws open,therefor opening
the (CIRCLIP ) and allowing you to place it over the pin and into the
recess. Hope this has been of some hellp goodluck T.C.
Mar 29, 2013 | Ryobi Saw. 13 Amp 10 in. Sliding Compound...
I took apart the handle for my Toro Trimmer Model number 51972 and a spring fell out and I'm not sure where/how it goes back into the handle. I took it apart because the trimer runs but the spool does not...
Hello, Hopefully the exploded parts list can help you out... I've done the reassemble of a trimmer handle once and explaining it can get dicey. The only suggestion that helped me was to have scotch tape handy to act as a third hand when holding small items between two other parts. You don't actually wrap the item, just place it on a small piece of tape - when the item is in position the tape removes easily. Your diagram link is the top one. Good Luck!
http://www.poulan.com/node7925.aspx
Aug 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Ryobi RLT30CESN. The started cord broke
Dont remove the center screw out of the spring pully or the spring will fly out. you put in the cord while the spring is assembled inside. Take the housing off but do not remove the pulley unless the spring is broken. The string can be put in using needle nose pliers from the inside of the housing once it has been removed. once installed you wind the cord around the pully and then turn pulley untill you get proper spring tension. Once tension is achieved you fish the cord back threw the eyelet coming out of the housing and tie the handle to the cord. It is a really simple and easy thing to do but hard to put into words.
Nov 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Is the fuel mix on a ryobi gas trimmer 50-1 or 32-1 ?
My Ryobi 720r is 32-1 but just to be sure go to www.managemyhome.com and download your owners manual to be sure.
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
