Question about Insignia IS-LCDTV32 32 in. Television
Power light is on but no picture is showing. - Insignia IS-LCDTV32 32 in. Television
  • sahid97 Jul 03, 2010
    WHEN THE TV IS TURNED ON, THE POWER LIGHT COMES ON BUT NO PICTURE, I MEAN THE SCREEN IS BLACK.
    THANK FOR THE HELPFUL SOLUTION.
  • 10,594 Answers
It sounds problem with back light inverter board that is not providing back light to view image of lcd screen.
Replace back light inverter board that would be located on side of cld panel and would be covered with shield.
Also check power supply voltage going to back light inverter board, its approx +24V
Thanks.
Posted on Jul 03, 2010
  • 484 Answers
Hello, The reason your picture is not coming up on your screen is because there is a problem on the relay board of the television. The television is receiving power but it is not reaching the main panel of the television. All you have to do is to open up the television, then trace the plugs wire back to the inside of the television and you will locate the power panelof the television, you will then see a cable that connects the power panel to the screen. Replace this cable and reverse the process of dismantling for reassembling it back together, then you plug it to a power source and turn it on. Always make sure your television is properly plugged whenever you want to turn it on, because wrong inflow of power could damage some major components of the television. Take care
Toshiba LCD 2009 TV picture won't show when turned on but sound works fine. Picture shows after 4-5 minutes. Help...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | Toshiba Televison & Video
Ario hc3269 no picture
Power supply failure. The power indicator only shows that power is getting to the TV
Dec 09, 2012 | Televison & Video
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Red light wont show picture
This is either a bad capacitor somewhere in the tv, or the very common power supply/high-voltage transformer.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv blue light shows That TV is on But no picture
YOU PROBABLY HAVE A PROBLEM WITH THE POWER SUPPLY BOARD. DEFECTIVE CAPACITORS.
Jul 17, 2009 | Polaroid Televison & Video
No picture on tv
Red light comes on but no picture
Aug 29, 2008 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
78 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
