Question about GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher leak dripping down side of drain solenoid
Model # GSD1200T63 there is no air gap. With each change in cycle to drain, there is about 2 ounces of water leaking down the back side of the drain solenoid.
The leak does not seem to come from the drain pipe connection. Can the leak be in the drain solenoid?
This dishwasher was installed in Noember 1994. If this is not a major problem to fix, I would like to repair it myself; that is, if you can provide me with a few instructions. Thank you..
    Top Expert:
  • GE Master
  • 45,586 Answers
It is possible that the plastic has developed a crack at the end of the threaded section
if you are handy with tools , turn the water off and remove that assembly( turn the power off at the plug)
check with a service agent spares department first as that part may not be available because of the age
Posted on Jun 13, 2017
catriver
  • 878 Answers
SOURCE: dishwasher drain solenoid
Snoopy, first of all you did a good thing when you ordered the timer. I have got stung on this model by just changing the solenoid. The fact is the timer is stalling and sending too much voltage to the solenoid and burning it up. Just order the new solenoid and install it. The solenoid is a AC circuit so it doesn't matter which way the harness is on, you should be just fine with the new timer..Catriver..post back.
Posted on Mar 05, 2007
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
SOURCE: Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Posted on Oct 25, 2008
SOURCE: leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Posted on Nov 11, 2008
SOURCE: We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
Not Draining
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control board
Sep 15, 2009 | Frigidaire 18 in. FDR252RB Built-in...
Won't drain completely after a cycle is completed
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Aug 31, 2009 | Whirlpool Dishwashers
Dishwasher won't drain after cycle completes
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Replace if defective (note: uncommon problem)...
Aug 12, 2009 | GE 24 in. Profile PDW7300G Built-in...
There is a lot of excess water in our dishwater when the cycle is complete.
HI, i would insect these areas below to address this drainage issue you are experiencing.
2. Broken belt
3. Pump
4. Drain solenoid
Jun 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Check the following areas to combat this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jun 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Viking dishwaser turns on, but I can tell that it is not cycling.
Check the following to address this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 03, 2009 | Viking DFUD042 Built-in Dishwasher
Won't drain during the final cycle, water comes out on the floor
CHECK THE FOLLOWING--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Kenmore Dishwashers
Dishwasher stops after 10 minutes inlet/drain light flashing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
ASKO1385 DISHWASHER
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control board
Dec 08, 2008 | Asko 1385 Dishwasher
GE 24 in. GSD2220Z Built-in Dishwasher Logo
132 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
