Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
1972 Farmall 656: Shift linlage sticks, cannot move gear shift side to side or forward/backward. cannot figure out where the linkage is sticking. Solutions?
Why has my forward and back gear shift movement become stiff?
of course it could be dry linkage and some WD40 might help for awhile .
Jun 05, 2016 | Cars & Trucks
When you put the car in gear to drive the letter M is beside the letter D for driving??
It stands for "Manual". It allows you to shift gears manually, without a clutch, for those performance oriented drivers. You can also use it to stay in low gear for climbing steep hills or driving in snow. Once you shift into "M" by moving the stick to the left of the "D" position, you should see a number "1" just above the "M", letting you know you're in first gear. Pushing the stick forward or backward shifts gears.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Jan 08, 2015 | 2009 Cadillac CTS
Mk3 golf gti stuck in 5th gear cant move the gear stick.
CHECK THE SHIFT LINKAGE. TO RULE OUT INTERNAL TRANS PROBLEM,. REMOVE SHIFT LINKAGE AT TRANS AND SEE IF YOU CAN MOVE SHIFT LEVERS
Dec 18, 2014 | Cars & Trucks
Shift linkage
remove floor deck plate. follow linkage down to see if it is movimi into high or low range. if it is remove cover on side of rear end housing .(5sided cover, you should lose maybe 1-2 gallons of oil} look inside trans and move shift lever you should be able to see fork move if not remove shift cover to find broken or worn parts make sure no slop exists in linkage or under range cover
Mar 13, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
My stick shift wont go into any gears, it only moves forward and backwards. this happened when the stick was being moved into reverse. what happened to my stick shift?
it sounds like the shift linkage came off the shifter, pull the shifter boot up and you should be able to get to the linkage
Mar 05, 2011 | 1993 Saturn SL1
Gear stick will not move from park !
Make sure you car is actually in PARK, Easy to do, Just disengage the parking brake (emergency brake) and attempt to push your car both forward and reverse to ensure your car isnt in neutral. If you cant budge the vehicle your good to go! If it rolls forward it may be in neutral or a forward gear. if it rolls backwards it may be in neutral or reverse. If it rolls both directions its in neutral. On that note if it moves at all skip to the third step (***) and make sure the transmissions shift bracket is in the park possition. Depending on your cars transmission model the parking gear is located all the way left to the farthest possition or all the way right to the farthest possition) One direction will put you in Park, the other in will put you in 1st gear, If your in 1st gear the linkage should be too far away from the shift plate to connect if your column says you are in park. DO NOT ATTEMPT TO START YOUR CAR WHILE IT IS IN A DRIVE GEAR AND THE LINKAGE IS DISCONNECTED IF YOU ARE ABLE TO START YOUR CAR IN ITS CURRENT STATE DO NOT MOVE THE TRANSMISSIONS SHIFT BRACKET UNTIL LATER IN THIS INSTRUCTIONAL!!!!!
* Floor shift automatic, the push pin lever (located inside your shifter/gear stick) may be malfunctioning. You have to pop the grip off and inspect the white plastic pin inside the shaft to see if it is damaged, also check inside the grip while you press the safety release (shift lock button) to ensure the internal slide mechanics are propperly working). Also check for anything obstructing the levers movement inside the floor housing.
** Column Shift. Make sure your pull pin lock is working properly (disengages the shift lock when you pull back the gear shift before you select a gear) if its broke theres two possible behaviors you'll experiance -1. You cant pull the gear shift back at all or -2. No effort or less than normal effot is required to pull back the gear shift. If all that checks out then you have to inspect the steering column linkage bar (you may have to remove some of the steering column housing to view it. Make sure the bar isn't bent or that its movement isnt obstructed.
***Automatic Transmission Linkage Check - Look under the kick panel located above the gas and brake pedals.........Once linkage is located under the dash (kick panel) disconnect it and try the gear shift. If the cable moves under the dash then reconnect it and move on to the next step.
Now block the wheels and climb under the car and disconnect the linkage from the transmission and have someone work the gear shift while you see if the cable is operating propperly, if the linkage moves (as it should) then try shifting the transmission back and fourth by hand while the linkage is disconnected., If the shift bracket feels stiff or is dirty clean it off with non corosive chemicals so you dont damage any seals. If the bracket operates smoother go ahead and reconnect the linkage and try shifting with the column again. Be sure to move the shift bracket back to the park position and make sure your shifter column is in park as well before you reconnect the linkage, if you dont you are sure to run into more issues.
Hope this helps you out! If all the mentioned area's above are in working order then your problem is with the car's transmission and you should take it to a speciallist.
Feb 03, 2011 | 1995 Jaguar XJ-R
After driving for less than a kilometer, i pulled over to drop off my niece; pulled up the hand brake and set the gear to P (parked) mode. after my niece alighted, i changed my mind about parking the car...
Perhaps the shift linkage has slipped and the car is actually in neutral. Try shifting to a lower gear position.
If the car doesn't move in any gear position, you may have a problem with the shift linkage or transmission.
Jan 17, 2011 | Toyota Corolla Cars & Trucks
1997 pontiac sunfire manual transmission won't shift out of gear.
What you can try is to remove the shift cables from the transmission side. then move the shifter and see if everything is free if it's still sticks then the cables are going to be replaced. if everything is moving with the cable off. then you need to remove the shift tower on the tranny (where the shift cable is I belive it's 5 bolts) remove the tower and you will see the shift pin. Inside the tower there is a cotter pin that breaks and that will cause you to have one gear and unable to selected another gear. If you are not mech inclined I would no attemped the shift tower repaire, the cables do it will save you money. The shift tower has bushings that can fall into the tranny.
Jul 02, 2009 | 1997 Pontiac Sunfire
Suzuki vitara transfer box got i stuck in 4x4 low
sounds like you may have jamed the linkage. youll have to look underneath to see. back in hunting season i had a tire flip a stick into the linkage of my F-150. thought i had broke some thing till i look under and saw the stick. whew what a relief. when shifting in and out of 4x4 always put tranny in neutral and set parking brake. when shifting out you can move backwards slowly and out shift easier. gl
Feb 20, 2009 | 1999 Suzuki Vitara
I have a 98 Concorde
You need to check the linkage. Under the car, the section that connects the gear shift stick to the transmission rods.
Nov 09, 2008 | 1998 Chrysler Concorde
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
645 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
