My Harman Kardon 300B receiver has a humm in the left channel. What should I check first? Any ideas would be greatly appreciated!
    Brigadier General:
  • 8,546 Answers
Isolate it to a source if possible; make sure none of your cables or speaker wires run by power cords or sources of high magnetic fields. I had hum caused by track lighting.
Posted on Jul 04, 2010
Blown front channel?
Hook one of the other speakers to it to see if the problem is speaker or amp.
Dec 26, 2013 | Harman Kardon AVR 335 Receiver
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
Left channel don't work
The IC in it is fied for the left channel.
Oct 29, 2012 | Harman Kardon HK 3370 Receiver
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
Have digital feed connected (white, red, yellow) to DVD connections 6 & 13. Get picture but no sound. Sound is OK on VID1 input from satelite. Any ideas?
so you have the yellow out from dvd player to yellow in on the receiver (composite video) and the red and white out from dvd player to red and white in on the receiver (right and left audio channel) . you can also plug in the orange rca (digital coaxial audio) go to your menu on the Haman Kardon receiver and make sure you select the right audio input. mine is a Harman Kardon AVR146 push th osd (on screen display) on the remote. go ti the input setup and select the appropriate audio input
Dec 05, 2009 | Harman Kardon AVR 320 Receiver
NO LEFT, RIGHT, AND CENTER SURROUND
hi there
have u tried connecting the centre speaker to another amplifier to see if the speaker actually works....
if it does then it cud be the output transistors blown or the actual OP-Amp for that channel
Feb 23, 2009 | Harman Kardon AVR 130 Receiver
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
83 people viewed this question
 Grubhead
Grubhead
