Question about Toshiba Office Equipment & Supplies
HOW DO I PLAY A DVD ON MY TV? TV IS LG,,PLAYER IS TOSHIBA..
    Guru:
  • 528 Answers
Hi. Depends of what type of cable you are going to use. Commonly used cable are the RCA cables. These are cable with three connectors red,white and yellow. Plugged in the red, white and yellow connectors at the back of your toshiba. you will easy identify the ports since they are all color coded. red goes to red port, white goes to white and so on.. Now, on the other end of the cable. You will plugged it at the back of your TV. it is color coded also same as your Toshiba. If there is empty slot in video 1 then plug it there. Set the TV using the remote to video 1 then turn on your Toshiba. If you see the Toshiba opening screen, it means that you are now succesfully connected to your TV. Enjoy watching!
Posted on Jul 03, 2010
  • Archie Cruz
    Archie Cruz Jul 03, 2010
    Here's the procedure on how your are going to play your DVD's
    1. Pop-up the CD tray on your Toshiba player
    2. Put the DVD disc that you want to Watch
    3. Close the CD tray
    4. Wait the Toshiba to read the DVD
    5. Menu of the movie will comes out Toshiba was able to read the DVD
    6. Click on play if you want to watch the movie
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do i fix my toshiba dvd player?
Select correct input in your tv. Look for cable conections and the correct input in your tv.
Aug 03, 2014 | Toshiba Televison & Video
I cant get my lg ht303su system to play sound from my television how do i do this?
Connect the RCA cables ( red, white, yellow cables) to the necessary jacks o the DVD player and tv..the DVD player should have an "AUX" input amongst the other inputs eg DVD,USB etc..this allows you to play sound from the TV through the DVD HT
Jan 05, 2013 | LG HT303SU Theater System
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
We have a 23" Toshiba with a internal DVD player.
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
27 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
