Question about Emerson Televison & Video
We have an Emerson CR20203M8 20" television that has absolutely no sound until the volume gage reaches 26. At full volume, we can barely hear it sitting 5 foot away.
  • 2,335 Answers
I have not been able to source a user manual for an Emerson TV model CR20203M8, do I have that model number correct?
My generic advice for you is to try a different cable for your TV to rule that out. A poor connection can cause the symptom you describe, and it is a much cheaper fix than any kind of service on the TV itself.
If you are using a screw-on type cable that carries video and audio, just replace it with another one. If your sound is coming from a set top box through red and white RCA cables, then try replacing that one.
Incidentally, if replacing your cable doesn't cure your problem, may I suggest running the sound through your stereo or portable audio device rather than trying to repair your TV? I suspect any repair cost to approach the cost of replacing the set entirely. Your TV may have a headphone jack on it, which you could connect to a small pair of speakers (like computer speakers) to extend the life of your TV and make the audio loud enough to enjoy watching it again.
I hope that helps.
Posted on Jul 03, 2010
Chasis CTC 187CN3. low sound, barely audible at full volume.
Hi
If you are keen on electronics this challenge lays on the sound IC and associated circuitry. You should first check if this IC is fed with the appropriate voltage (schematic needed) and then check all the electrolitic capacitors around the IC. I suggest to disconnect the speaker(s) and test it with a l.5V cell respecting polarity (+) and (-); you should hear some noise.
Sully
Sep 23, 2013 | Televison & Video
I cant hear the tv
Hello drive2darim,
OK first check you converter box, Cable TV/ Satellite TV volume control and turn it up to 100%.
Then check the menu on your TV for audio settings and set them to there default settings. This should take care of this issue.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 13, 2009 | Emerson Televison & Video
Can hear no sound during any form of playback
mybe she turnd off the sound try to turn it back up, on the side there are these buttons that go up and down, click on the one that goes up.. hope this helps
May 27, 2009 | Samsung Eternity Cell Phone
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Can barely hear sound even though volume is max
thebuzzer of your phone is defected, replace itand replace also the earpiece
Apr 09, 2009 | Samsung Eternity Cell Phone
Tv rca televison model DZ7649 Entertainment series
  • there is a loose contact in volume control or switch.
  • clean volume control with cleaning chemical & change volume switch.
  • hope this will help.
Oct 12, 2007 | Televison & Video
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
