Question about Dell Latitude D800 Notebook
Hard drive not picked up or recognised any jumper settings ?
    Brigadier General:
  • 10,406 Answers
No, it is _not_ "jumper" settings. The new style of disk-drives ('SATA') do not have any jumpers.
Take the computer to a qualified technician, and have them remove the hard-drive, connect it to one of their computers, and test it, to see if it still is working.
Posted on Jul 04, 2010
How do I find plan of the jumper settings on my internal hard drive?
if its sata drive plug it to sata 0 if its ide it should have the jumper settings
Oct 07, 2014 | Computers & Internet
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Apr 07, 2011 | Maxtor Hard Drive
I have a Samsung SP2514N (250GB/7200rpm/8M/PATA) drive that I am trying to use as a USB drive on my laptop with Vista on it. The device manager shows that there is a drive there, but that is all. It does...
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
Feb 15, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Not recognised
Hi, do you have 2 hard drives in your computer,
if so make one a slave, there is a jumper on the back of the hard drive,
change it to slave, or if its the only hard drive in the computer
put the jumper on master,
hope this helps
Nov 28, 2010 | Maxtor Hard Drive
I have a m2n61-ax dell board,I install a second dvd rewrite lg window will not see the drive????
if These Are IDE devices, ensure That The Jumpers Are Set To Slave And Master. If The Device still Is Not Recognised, Try Putting It On The Secondary IDE Channel, with A seperate Cable. Or Add it to The Hard-Drived Cable. If The Hard-Disk Is Jumper-Set as Slave, Move Jumper-Pin ( Small Plastic Block ) on the rear Of The Drive To Master.
Mike @ Compurepair.
Oct 16, 2009 | Dell Computers & Internet
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
Aug 08, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
Hard driver (seagate)
hi,
is it a sata or ide (pata) drive? does the bios recognise it yet? if it does then you know you have a software problem which could mean you may just need to partition or format the drive.
if the bios can't even see it then you will need to change the jumper settings on the harddrive to make it compatible with your mother board.
good luck
smeags
Jan 07, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Quantum fireball 40 not recognised as master
goto the quantum site and verify the jumper setting on the drive first
if correct then.. check your sata cable is good...
check the bios to boot options so the quantum is set to boot...
under boot options .. hard drives.. sort the drive to be the first to boot
Jan 04, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
New Install
replace your data cables and retry. else check your jumper settings to set as slave on the cdrw and master on the hdd.
Sep 17, 2007 | Asrock K8 Combo-Z Motherboard
Dell Latitude D800 Notebook Logo
26 people viewed this question
Alun Cox
