Question about HP Photosmart 385 GoGo InkJet Printer
Print cartridge craddel is stuck
The print cartridge craddel is stuck
    Brigadier General:
  • 10,406 Answers
Stuck, as in it won't move to the position for a ink-cartridge change, when you tell it that you want to make a change, or stuck as in physically "frozen" into one position.
What's cheaper: buying a new printer (that accepts the same cartridges as your current HP printer), or paying a qualified technician $50 to $75 to _try_ to fix it?
Posted on Jul 04, 2010
Sounds as though it's printing but why isn't it actually printing?
I would suspect some residue from the stuck cartridge is clogging the new one
Nov 05, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Kodak 7250 print head jam
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Print head and cartridges are stuck
There should be a button on the front of the machine which brings the cartridges out so that you can change them. Read the manual.
Jun 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Z11 Printe Cartridge Stuck
first push cartridge inside and then try push out side and then keep the cartridge at right place and push it inside after pushing in make sure some green light blinking and start printing it
Feb 25, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Print cartridge cradle is stuck
My printer keeps telling me my print cartridge is stuck how do i fix this
Nov 17, 2008 | HP Photosmart 8250 InkJet Printer
Photo ink cartridge stuck
I had the same issue. Don't try to force the cartridge out though. After being stuck to the paper, tearing the remainder of the film won't get all of it out of the cartridge. You'll need to print a 'dummy' page to get the last bit to be pulled out and afterwards the printer will automatically release the cartridge allowing it to be pulled out normally.
Apr 21, 2008 | Canon SELPHY CP720 Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP Photosmart 385 GoGo InkJet Printer Logo
533 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
