Question about Seiko Watches
Seiko Women's Stainless Steel Two-Tone Watch. I NEED TO SHORTEN THE BAND AND REMOVE SOME LINKS, BUT I DON'T KNOW HOW. (NOT THE USUAL PIN HOLES).
    President:
  • 1,561 Answers
Locate the spring bar on the watch's clasp. When you remove the links, the spring bar should be at the end of the last link you plan to keep, so you will relocate the spring bar before removing the links.
Insert the jeweler's screwdriver into the spring bar's hole. You'll be able to push the spring bar along until you reach the last link you plan to keep.
Decide how many links you need to remove to get a good fit.
Locate a hole at the top of the first link you want to remove. Insert the screwdriver into the hole.
Press down on the hole in the link and this will release the L-shaped pin. This will unlock the link.
Pull up on the link pin. It should slide out.
Repeat above step for the next link. On most watchbands, you can't remove single links and must remove two at a time.
Remove the links from the watchband.
Continue to remove the links two at a time until you reach the desired length.When you have the number of links you want, make sure the link pin is in place for your final link. You'll need to use a jeweler's hammer to make sure the link pin is secure.
Take care.
Posted on Jul 03, 2010
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How to shorten watchband
    It all depends on the style of the band.
    Go to where the links are all the same size, not tapered at all.
    If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
    If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
    Dec 28, 2009 | Seiko Watches
    Adjust watch band for Seiko 7T94 Stanless Steel Band
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
    First you have to find out what sort of pins or even screws are used to keep links together.
    Examine both bracelet sides and find the side where pin ends have a groove.
    Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
    For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
    Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
    NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
    Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
    After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
    After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
    It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
    Make sure that pin ends are flush with bracelet. If needed- hit few more times.
    Job done!
    If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
    Don't forget to rate, please.
    Apr 04, 2009 | Seiko Watches
    Broken Watch band
    you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
    Jan 07, 2009 | Watches
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    Watch band sizing
    OK, I make an attempt:
    I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
    If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
    You can push it out with a blunt sewing needle (break off the tip).
    Remove links on both sides of the watch when resizing it.
    Hope that helps.
    Critter
    Dec 26, 2008 | DKNY 1009 Wrist Watch
    Stainless steel band won't snap into my watch
    Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
    Another way is to use curved spring lugs (pins).
    Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
    Watch band links.
    you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
    but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
    Jun 10, 2008 | Seiko SXGL61 Wrist Watch
    Seiko Watch band Adjustment
    hi. you have to push or hammer the pin out in the direction showen by the arrow, so the arrow is dis-assembly direction.
    May 21, 2008 | Seiko Diver's Watch
    Watches Logo
    144 people viewed this question
    Top Seiko Watches Experts
    Vernon Taylor
    Are you a Seiko Watch Expert? Answer questions, earn points and help others
