Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Problems with the infusor of espresso delonghi4000
I have an espresso delonghi 4000 machine and the problem is that the infusor went down and stuck right there.i can't move it because it's fixed and touch the ground of the machine.the salver went out so that the infusor is in it's place now.please help me because i don't have any ideea how to fix it!!!
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
SOURCE: DeLonghi EC140 Espresso filter
Why is the coffee not flowing aas fast and why is the crema not consistant?
Posted on Jul 09, 2009
mnwarfield10
  • 452 Answers
SOURCE: Delonghi 3400, spend grounds going wrong place
we repair 07779933829
Posted on Jan 26, 2011
mnwarfield10
  • 452 Answers
SOURCE: infusor is stuck at bottom of machine after
you need the unit reset ... u shut the door didnt you :)))) just let you no too we repair them postal service covering anywere..
Posted on Feb 28, 2011
ginko
  • 19396 Answers
SOURCE: alternating 3 lights (1 cup,
Hi.
The machine is not flashing an error message. When a problem is detected you get an error message on display.
First hold down ESC (or STOP/CLEAR depending on model), just in case machine is stuck in programming mode.
Disconnect power cord for two minutes. Connect back and try a reset if the problem is not fixed:
•Press the CHANGE button and the appliance displays "RESET TO DEFAULT YES";
•Press the OK button to reset the factory default values;
•Press the MENU button to exit programming mode or NEXT to change other parameters.
If that does not work, try holding down rinse or descale. If the machine starts rinse or descale, complete the procedure. If machine gets stuck in rinse or descale, keep filling the container while performing the procedure.
If all that does not fix the problem, call Delonghi at the number listed on the owners manual, the machine is defective.
Try all the rest first, or Delonghi may ask you to do some of the same procedures while operator is waiting at the phone.
Regards.
Ginko.
Posted on Apr 06, 2011
Delonghi problems
I had a similar problem which was solved by replacing the infusor. I was able to find a new one on eBay for about $40. Hope this helps.
Jul 28, 2014 | De'Longhi Magnifica Esam4200 15-Bar Bean...
The infusor on my delonghi ESAM 4000/4200 is jammed down, how do I replace it
This worked for me. I had the main power switch, at the back, on. The machine was switched off with the power botton on the front. Then I disconnected the power plug and reconnected it. The machine resetted and works fine now.
Jul 14, 2012 | Coffee Makers & Espresso Machines
Our machine just went "bang" and blew. can't
sounds like pcb and motor .. the motor gose and takes the pcb down.. might be lucky and could be just the motor will need to be tested ...bsc appliances bristol ...07779933829 postal service too.
Feb 20, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser will not come out. It is stuck in the down position
motor problem or turn unit on let it set up so its ready to use.... turn off again on button ..let it shut down ..do not turn off at plug . now try... bsc appliances 07779933829 postal services too.
Jan 15, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Diffuser will not remove it appears stuck at the top? Red buttons go in OK but it will not pull out
I have the same problem. I unscrewed the bottom part of the infusor and the whole infusor assembly fell at the bottom once I switched it on. Everything is stuck now. Please help!
Dec 02, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Poor performance
Maybe the screen is clogged with coffee oils, or the boiler needs to be descaled, or the pump is going out.
May 20, 2010 | DeLonghi BAR 14 Espresso Machine
My delonghi magnifica bean to cup machine blows fuses
at a rough guess when you twisted the switch you have shorted out the power wire to the ground wire creating a dead short
take it to an appliance repair shop to fix what you broke
Sep 08, 2017 | DeLonghi Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
61 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
