Question about Blueant Z9i Bluetooth Headset
I'm trying to pair my new BlackBerry 8520 Curve with my BlueAnt ST3 but when I put the passkey #0000, it doesn't like it...they won't pair
It will not pair.i have a blackberry curve
Posted on Jul 13, 2010
I need a pass key
0000 is the passkey for blueant bluetooth products.
This link provides the step-by-step pairing procedure.
http://www.myblueant.com/knowledgebase/pairing/products/st3.php
Dec 21, 2010 | Blueant Supertooth 3
Having difficulty pairing BlueAnt ST3 with Blackberry Curve. Blackberry recognizes BlueAnt but does not accept code of 0000. Says "connection failed"
Make sure the device is in pair mode, to put it into pair mode hold the green button down until you hear a language loop (with the device off). When you hear the language of your choice let go of the green button and press it once right away. When you hear that go to your phones bluetooth menu and enter pin code 000 when prompted. If this does not work do a hardreset on your phone by removing the battery while it is powered on, when it is back up research and repair and it should work.
Rylan
Oct 14, 2010 | Blueant Supertooth 3
How do I restore factory settings on my BlueAnt ST3. I have a new Blackberry and every time I try to pair them the Blackberry comes up with 'Unable to pair with BlueAnt ST3. Try again?' and every time I...
Here is how I got my Samsung to pair (on page 12 of the Blue ant manual):
Deleting all Paired Devices & Phonebook entries:
1. Ensure the SUPERTOOTH 3 is switched OFF, press
& hold the Volume Up (8) Button.
2. Whilst holding down the Volume Up (8) Button, press
the MFB (1) for 1 second or until a distinctive melody
is heard through the speaker, the software version will
then be announced. Once this occurs, please switch the
SUPERTOOTH 3 off for a minimum of 10 seconds.
All paired devices & phonebook entries have now
been erased.
Go back in and pair your phone, use pass code 0000 and let it reload your address book and you should be good to go
Sep 29, 2010 | Computers & Internet
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
I lost the passcode to my bluetooth i tried 0000 9999 and all others no pairing its a bluetooth 10799 and it goes in ciggerrette lighter and u can talk out loud please help dont want a ticket lol
How to connect or pair a Blueant Bluetooth handfree.
1. Switch off the Blueant:
i.e. push the microphone inside the Blueant.
2a. Press and hold the GREEN telephone symbol (or Accept) pushbutton
On the Blueant flat face for 8 seconds. (this makes unit go into “pairing” mode)
2b. at the same time switch Power On to the Blueant by pushing out
the microphone on the side of the Blueant.
3.The Bluetooth Indicator will turn a blinking red/blue,
when you see this, release the Accept Button .
The Blueant is now in “pairing” mode.
4. Get you mobile in Bluetooth search mode to pair with a new device.
5. The Blueant will request your mobile device for a password.
6. Enter the password= 0000 , the devices now will be paired.
7. Set the Blueant as a trusted/authorized device, if this is option in your phone.
Mar 18, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I am trying to connect my blackberry storm to my blueant ST3. It asks me to enter my passcode, but when I do, nothing happnes and keeps asking to try again.
initially check whether both the devices are compatible when your pair them. Then try to give the same passkey on both the devices like 1234 in your blackberry and also same 1234 on your blueant ST3 and check.
Dec 29, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot pair blueant ST3 wih Nokia 6300
Reste the ST3 and then pairi again. It worked for me. Check this link:
http://www.myblueant.com/knowledgebase/reset/st3.php
Deven
Dec 25, 2009 | Blueant Blue Ant 091193 Supertooth II...
Blue Ant ST3 will not recognize 0000 passcode.
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Jun 11, 2009 | Blueant Blue Ant 091193 Supertooth II...
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Blueant Z9i Bluetooth Headset Logo
364 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
aliasger yq
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
