Question about Sharp Televison & Video
I have a Sharp 27R TV Model S450 Componant-in PIP-MTS that needs
I have a Sharp 27R TV Model S450 Componant-in PIP-MTS attached to my Comcast cable line and cannot get a Universal Remote device to work with it. Do I need a Sharp remote or am I doing something wrong
5 Suggested Answers
Sparky-UK
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
aprmaejun
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: Can My Comcast TV Remote Connect To A Sharp TV
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
Posted on Apr 13, 2009
SOURCE: Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Posted on Aug 11, 2009
We cut cable and are trying an antenna without success. Is the Sharp component-in Pip/mts compatible with an antenna?
is this a TV , if so it should work with an antenna if you select the proper input type which might be AIR or antenna
Nov 13, 2015 | Sharp Cameras
Hey there i have a sharp tv mts stereo pip and it turns off after 10 seconds.. i turn it back on.. and it turns off after 10 seconds.
i sujjest you download the complete 46 pages service manual from my ftp sight,and do a factory reset of the set,request it at computec40@hotmail.com
Nov 04, 2009 | Sharp 32F640 32" TV
Dec 01, 2008 | Sharp Remote Control
Sharp tv/model no.27R-S50 . need service setup info.
press and hold volume up, channel up, then plug in tv. Should go into demo programming mode, worked on mine.
Apr 16, 2008 | Sharp 27R-S50 27" TV
HD Picture is Scrambled, but Has Sound
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Televison & Video Logo
261 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
