Question about Kenmore 24032\24036 Top Load Washer
Won't disengage the aggitator - Kenmore 24032\24036 Top Load Washer
Agitates during draining of water, does not stop.
Posted on Jul 10, 2010
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Jul 03, 2010
Disengage old hydrostatic transmission m11
rock the mower back and forth hard may need three people for this rock it till you pull the lever out for disengage
Sep 14, 2014 | Mtd Garden
Yamaha wolverine 350 4x4 starter won't disengage
I would just get another starter unless you can rebuild it.
May 22, 2013 | kawasaki KLX 300 Motorcycles
Fills then wont't aggitate
sounds like a faulty timer or loose cable or circuit board ,only way to tell is have it checked out by engineer
Dec 13, 2011 | Maytag Washing Machines
Washer won't aggitate, it will spin and fill up. there's also oil coming into bottem of tub.
there is a gear box sort of thing in the washer which in your case seems broken as the oil in the gearbox is pouring out..
you should get a professional mechanic take a look at your washer to fix it
Oct 26, 2011 | Washing Machines
I have an LG WM2277HS which will aggitate, but will not spin & rinse.
make sure the door safety switch is working correctly ,, if it doesn't show as locked, the machine won't spin
Jul 15, 2011 | LG WM-2277HW Front Load Washer
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
90 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
