Question about Maytag M3X05F2B Air Conditioner
How can i install my air conditioner in a horizontal vinal window
DISCHARGE GRILL -- is installed in factory to provide HORIZONTAL airflow. If a VERTICAL airflow is desired, the direction can be changed by rotating this. Most SLATS w/c allow change of airflow are broken...
dear sir/madam
as long as i know it,s hard to convert horizontal flow type of grill to vertical type of grill of air conditioner coz all window type of air conditioner is specially design for it,s desire model and horizentle type of grill there air flow come from top of aircon and vertical type of grill aircon design for side flow type of grill.it,s different to each other,
ifor more information please contact to this link .
http://friedrich.com/index.html
thank you
hope answer the question.
please vote!
Sep 23, 2010 | Friedrich WallMaster WS10A10 Air...
We have a Goldstar airconditioner model GWHD6500R . Can we get a way to install it in a window that opens sideways?Right to left. Thanks mdye46@yahoo.com
Sure. You *must* install it horizontally as it is designed, however.
To fill the gap above the unit, you will need a panel cut-to-size. Otherwise, the hot air will recirculate back into the room.
Jul 15, 2010 | Heating & Cooling
Window too small for a/c
Unfortunately you cannot mount this type of A/C vertically. The compressor must be in the upright position or it will be damaged and not function in a short period of time.
May 30, 2010 | Goldstar R5050 Air Conditioner
Kenmore air conditioner is leaking
Your A/C have to be tilted to the out side of the windows!!! It will drain it self to the sidewalk.
Do not set your A/C horizontally perfect!!!
It has to have tilt up to 15 degrees to the outside of a window.
Outside should be lower than in side.
Aug 19, 2009 | Heating & Cooling
I was wondering if you can install the air conditioner vertical instead of horizontal since the window is too small
NOOOOO. The compressor in it is mounted and can only sit one way. If you install it sideways it will burn up the compressor
Jun 24, 2009 | Goldstar R5050 Air Conditioner
Wimdow Air Cond.
Sorry, that's a no. There are, however, window air conditioners made for casement style windows which are tall and narrow. I know GE used to have them. Check geappliances.com. There are also " portable " air conditioners which sit on your floor and vent through hoses to a window.
Jun 18, 2009 | Heating & Cooling
Vertical to horizontal
most all airhandlers have a second pan included . if not they can usually be purchased with directions to mount to the side of the coil for horizontal right or horizontal left application. remove the front panel and take a flash light look inside and you should see a cookie sheet looking pan on one side of the coil usually on the right side coil can usually be removed and reinstalled with the top of the coil facing the filter or the blower depending on how you want the air to go . just be sure the pan is under the coil and you will be ok . i have actually seen pros install them with the pan above the coil! and of course they flood the place. water of course goes down hill. the square donut pan used for vertical install stays in place as found. you will need to install a second emergency pan to catch any backup drips especially if you put it in an attic. you should find them at a sheet metal shop and they are basically a pan even bigger than the airhandler that catches any drip. it should be connected to a drain to the outside also and a float switch installed in case it fails to shut off the ac. better to get a no cool call than a flooded house call. try to put the second drain out over a door or window where it will be noticed before damage. good luck and remember you will have to relocate ductwork, electric drains filters refrigerant lines and if its in an attic a decked service area and a light and an outlet are required here in fla. good luckagain.
Oct 25, 2008 | Ruud Central System Air Conditioner
Maytag M3X05F2B Air Conditioner Logo
50 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
