Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error code 5010. what is it and how to correct
    President:
  • 1,382 Answers
There are several reasons to get this 5010 error in your printer but the most common one will be you would have caused this after pulling the printer to bits to fix a blockage. You can fix this issue by inserting the ribbon cables from the scanner into the circuit board properly.
Thank you !!
Posted on Jul 04, 2010
SOURCE:
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
How to clear error code 5010 on canon pixma mp460 all in one printer
Check the manual that came with it for the answer to the codes.
Jul 20, 2014 | Canon PIXMA MP460 All-In-One InkJet...
MY PRINTER SHOWS 5010 CODE HOW DO I CORRECT THIS PROBLEM PLEASE ?
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
Error code 5010
Canon only lists three 4-digit error codes for the MP500: 1700, 1851, and 1856. After much research and finding many other MP500 owners getting this same strange code, I have come to conclude that it's the code of DEATH. Sometimes you may get strange codes if using compatible ink cartridges. Unless you can get the printer to reset and clear, the only other thing to try is to go back to the Canon driver download page and reload the correct driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Apr 25, 2010 | Canon Pixma MP500 All-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 for cannon mp460 printer
Hello, The error 5010 refers to a scanner issue, make sure all the connectors are seated and all flat cables running to the scanner unit are firmly seated, turn printer back on and the error should clear. I hope this helps.
Nov 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
588 people viewed this question
Clive
Clive
old marine
old marine
Ekse
