My father has had to replace 4 relays in his Intertherm Furnace/AC in the last year, something must be burning these things up. I'm looking for a wiring diagram for his unit (Nordyne E1B012HA) 42000 btu...
  • Brian Niten Jul 03, 2010
    Give me a few days, I know someone with a book of Nordyne schematics.
    New Friend:
  • 9 Answers
Wiring diagram for E1EB012H Nordyne/Intertherm Furnace from owner's manual. If you want a better copy, I'll need and email address.
My father has had to replace 4 relays in his - father-replace-4-relays-in-his-pgo4udvlobv2sheptnserdfd-5-0.jpg
Posted on Mar 23, 2015
  • 29 Answers
I would check the current draw through the relay and make sure its not above the rated max on the relay...do this using a good voltmeter/clamp meter attachment.
Posted on Jul 05, 2010
My intertherm elec. furnace will sometimes not come on when the thermostst activatesit, I have to trip and reset the curcuit breaker then it will work ok for a day or so, where do I start to look?
It could be several things,a weak transformer,a poor connection, bad relay. I would contact Intertherm with your particular model number. http://www.intertherm.net/
Jan 15, 2015 | Heating & Cooling
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
I have a intertherm furnace and split intherm heat pump when i turn the thermostat on it just seems to hum out side at the heat pump whats the problem
First thing to check is to see if you have electric out there. The hum is probably the 24 volt relay that is telling the a/c to come on. The 24 volt relay gets it's power from the indoor unit.
Jul 06, 2010 | Intertherm P3RC-030K Air Conditioner
Intertherm furnace. Continuous cycling
Check for air restrictions or replace the filter, this appears to be lack of air in the mixture port if this is suppplied by gas
Jan 06, 2010 | Heating & Cooling
Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Jul 24, 2009 | Heating & Cooling
My Intertherm furnace will not shut off, the A/C cycles, but the blower runs unless I trip the breaker. I have replaced the t-stat.
It could be a couple of things; since you've already replaced the thermostat it could also be shorted wires from the thermostat to the furnace, or a siezed relay that controls the blower motor.
Jul 21, 2009 | Heating & Cooling
I have a mobile home furnace Intertherm #1378. The pilot light is on, but the burner will not light. The thermostat clicks on and everything seems to be running properly, but there is no flame. Last year...
First make sure that the gas valve is in the on position. There is a spring load diaphragm that will stick when not in use over time, When the t-stat clicks on for heat tap the valve with a hammer LIGHTLY. If it doesn't come on replace the valve.
Sep 28, 2008 | Intertherm Heating & Cooling
FURNACE OR AC WONT TURN ON
to see if it is the t-stat or the system you can unwire the entire t-stat and jump out the wires. never touch the blue to any other wire or you will blow the low voltage fuse on new board. if you jump red to yellow and your condensing unit cycles on the t-stat is wired wrong or wrong style. If not go check the yellow wire at cond. unit and see if power is even going to it.
Sep 24, 2008 | Intertherm Heating & Cooling
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
