Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Canon ImageClass MF-5750 fuser removal
Hello. Does anyone have a service manual for this unit? It looks like th fuser in mine is stuck somewhere and paper does not go through the unit when printing. Instead, it becomes accordianed at the input of the fuser. Maybe a paper sensor is stuck, disconnected, or dirty somewhere. Or maybe the fuser needs to be removed and cleaned-out. I've worked on many other printers, but this one looks like a real bugger to remove the fuser for inspection and cleaning. Any help would be greatly appreciated. Thank you.
  • Giulio Moro Jan 14, 2013
    I found the service manual over the internet and then found the fuser sleeve was damaged and needed to be replaced. I managed to locate one and replace it myself. Now the unit is working fine and has since found a new home where it will get put to good use.
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Main drive assembly
check this site: http://www.precisionroller.com/find/canon_imageclass_mf5750.htm
Jun 04, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon mf 5750
i fix the problem changing the heather......
May 08, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon MF 5550 Fuser error
More than likely you have a fuser failure.
either contact canon or whoever you purchased the machine from.
The most likely solution will be to replace the fuser unit.
Dec 10, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
347 people viewed this question
old marine
old marine
