Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Solution won't stay in the holding tank. It practically runs right through within ten minutes of having the power on.
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Oct 22, 2013 | Rainbow E series Canister Wet/Dry Vacuum
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
Quick Fix...takes 4 minutes max
Remove the switch by using instructions here:
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
(The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My Mom has a Dirt Devil Featherlite and the belt falls off all the time. I put it on three times today and it falls off within a few minutes. The belt post I put it on doesn't have anything to hold the...
It sounds like the belt is too worn and loose to stay on. Buy a new belt specified for that model of vacuum and install. Ensure that there is only a slight amount of give in the belt when you press the middle.
Jan 05, 2011 | Dirt Devil CE6100 Featherlite Upright...
My iRobot Roomba runs for about ten minutes, then shuts off. I can keep pushing the clean button and it will run for another ten minutes and stop again. Nothing seems to get clean.
Take the brush rolls out and you should see a copper disc. It is the dirt sensor. Clean it with Windex or some other cleaner. This works sometimes.
Sep 08, 2010 | iRobot Roomba 550 Vacuum
I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Jan 09, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Whether the machine is on or off, cleaning water in upper tank empties itself onto floor within 2 minutes.
You have a hose loose that is connected to the tank or your tank is busted where you can't see it.
Jul 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
90 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
