Question about Makita HM1800 64 lb. Breaker Hammer AC/DC
The bit does not lock in place just falls out or gets stuck in the concrete. Is this normal for it to be so loose?
    President:
  • Makita Master
  • 1,388 Answers
As the retainer shaft (part # 322550-8) wears it will begin to drop the bit. Also could be the roll pins that hold the shaft. Remove the two pins and take a look at condition. You could build up the metal with welder and grind to shape. Part is available at www.toolpartsdirect.com at a cost of about $25. Good luck with your repair.
Posted on Jul 08, 2010
Key gets stuck in ignition of my 1997 GMC Jimmy can't remove until I hear a click. It does this once in awhile.It sounds like a timer has it locked,when I hear the click only then I can remove the the
The steering wheel lock pin is probably not falling into place. Try some lock lubricant and jiggle the wheel back and forth a little bit. If that does not do it, you will have to take out the lock tumbler and free-up / lubricate the steering column lock pin mechanism.
Jan 15, 2015 | 1997 GMC Jimmy
Bit falls out of impact driver
There is a small spring at the back of the sleve which snaps. Try replacing it. it is only cheap.
Feb 02, 2013 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Have an FDV16VB2 and the bit vibrates loose after well securing
Your hammer drill is either defective or poorly designed. I had a Sears imitation hammer drill at one time that had a defective chuck from the very start.
Dec 12, 2017 | Hitachi Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
The bit in my Stanley ratchet screwdriver does not lock into place, falls out when screwdriver is pointing down
There is a small springs steel wire that fits into the chuck. the bit slides into the chuck and then into the spring and the spring holds the bit inside the chuck. This ring seems to be missing. Thus the bit falls out. You might try going to a hardware store and they make a device that is two magnets held together with a rubber band. When they are together there is a small hole in the center. You can slide any screwdriver or bit into the hole in the center and it magnetizes the bit or driver. Magnetizing your bits should keep them from falling out of the ratchet screwdriver.
Dec 04, 2009 | Tools & Hardware - Others
THE BIT DOESNT STAY IN PLACE
Could be 2 problems, first are you using the right type of bit to lock in this tool and second the ball that locks into the detent of the bit might be stuck or the ring holding it in has moved. Give me a brand and model number and I will find a breakdown for this and see if I can give you more help
Jul 27, 2009 | Black & Decker Pivot Plus Cordless...
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Makita HM1800 64 lb. Breaker Hammer AC/DC Logo
222 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
