My car dvd player says no disk but when I try to put the disk in it won't load.
MYSTRO
  • 6 Answers
SOURCE: player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Posted on Jun 22, 2007
likha
  • 790 Answers
SOURCE: Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Posted on Sep 09, 2007
  • 99 Answers
SOURCE: DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Posted on Mar 31, 2008
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
SOURCE: ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
Posted on Jun 10, 2009
"Loading" screen
time for a replacement .
Jan 05, 2018 | KLH KD1220 DVD Player
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
Disk won t load
if it is a brand new unit you have to remove the shipping screws that are usually on top of the unit, if these havent been removed you cannot load or eject a disk. They put theses in to prevent damage to the unit. If it is an old unit, ensure there isnt alread a disk inside the device, or worse that a child or etc hasnt jammed anything inside it.
Aug 08, 2010 | Rosen A7 Car DVD Player
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Myron & davis dvd problem
This indicates that the DVD Player is unable to detect any disk inserted in the DVD Player Compartment. Check the player using a known playable DVD and Music CD. If these operate normally, the Disk is probably faulty. If the known disk does not play, clean the DVD Laser lens as detailed elsewhere in these FAQs and try again. If unsuccessful, check that the DVD LID is seating properly and latching in the fully closed position. If this does not work and the product is within the warranty period, simply return it to the retailer from where it was bought together with your receipt as proof of purchase.
This is what I found about your unit.
If it is under warranty, the best thing is to bring it in for repair or replacement.
Disconnect the power from the source and hook back up. It may clear.
Mar 05, 2008 | Venturer PVS1950D Car DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
Top Televison & Video Experts
