Question about Parmak Solar Fence Charger
Where can I get parts for a Parmak low impedance fence charger serial number 3498346 model fieldmaster FM
4 Suggested Answers
  • 76 Answers
SOURCE: I just bought a Parmak 6 volt solar electric fence
I WOULD THINK SO BUT THE BLACK MAT BE THE POS. AND YOU MAY BURN UP THE CHARGER IF HOOKED UP WRONG BUT OTHER THEN THAT YOU HAVE GOT I THINK
Posted on Jun 24, 2009
  • 1949 Answers
SOURCE: I have the model DP-SP-LI solar fence charger and
try going to parmak web site
Posted on Dec 12, 2010
cbkoerner
SOURCE: We have a Parmak electric
Needs a new scr or diode. the diode is the fat black cylinder about the size of a pencil eraser - use any 6A, 1000V diode. Ther scr is a 40TPS12 1200V 40A unit. u can purchase both on ebay for less than $6.
Posted on Aug 24, 2012
I have Parmak S.E.3 fence charger, it's send energy out into wire but not enough to shock cattle, the unit is around a 7 acre field with 2 lines, what could be the problem?
Grounding is very important for an electric fence, especially in dry soil. I normally drive 2 or 3 - 6 foot long ground rods 10 feet apart then join them all together and run that to the charger using double 14 gauge or 12 gauge copper wire. You can get the roda at Tractor Supply.
Aug 19, 2014 | Electrical Supplies
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
We have a Parmak electric fencer, model # s.e.3 and serial # 4401002. It just quit working. When you plug it in it makes this humming sound and then quits. Any ideas?
That sounds like the circuit board has failed in the unit. you can call Parmak and see about either purchasing a replacement circuit board , or getting the unit serviced by them or an authorized service center.
Apr 21, 2011 | Parmak Solar Fence Charger
Installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Dec 19, 2009 | Parmak Solar Fence Charger
We have 2.2 miles of fence,the charger is good for 30 miles.We have a 8 ft ground rod by the charger. the fence is a continues loop. positive wire to fence, negative to ground. meter on the charger says it...
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
Oct 02, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
858 people viewed this question
Top Parmak Electrical Supplies Experts
 Kenneth
Kenneth
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
