Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Toy stuck in vacuum
How do you get things out of the vacuum tube? We have a kid's toy stuck inside that I've tried to get out, but it's just slightly too big to get around the curve of either end of the hose. suggestions?
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Clogged vacuum
You can start by taking off the bottom plate or top cover, which ever comes off, that is where the inlet starts going in and hopefully the clog is there. Could be in the hose also. But without the complete model number I can't look it up to see a picture of it.
Posted on Sep 01, 2008
reddevil6
  • 1673 Answers
SOURCE: Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Posted on Sep 02, 2008
How do you take a Eureka C2094 Type G1 apart
The kids can take it apart as well. (just joking). But any parts supplier has drawings that show what you need.
Jul 15, 2015 | Eureka Vacuums
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Not spraying water
Hi, I'm sure you've done this but double check that there is no blockage or kink in any of the water tube things! That might solve itXX
Jan 31, 2012 | Bissell 7920 ProHeat Pro-Tech Upright...
Cleaning out tube that goes up the center of the vacuum. I had been just flipping and dumping. The tube was plumb full of dust. Got most of it out and then decided to put a paper towel up to clean more and...
The easiest way to clear a blockage from the hose is to remove the hose from the machine, then to use something like a broom handle to dislodge the obstruction. To remove the hose from the cleaner, please refer to the support guide linked below:
http://www.dyson.com/support/help.asp?article=119&product=DC07-SY-HEPA_US
Hopefully this should enable you to resolve your issue without further assistance. However, if you've tried this and are still concerned, please get in touch with us directly on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 05, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
My extension tubes were put in incorrectly and I can;t unstick them. Suction is not great think something is stuck in tube.
Hello There! I had the same exact problem. Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it. So, try getting replacement tubes & it'll work for sure!
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
I have the dyson animal. There is something stuck in the wand tube and everyting is getting caught on it. There is very little suction from the wand. How do I get the wand apart or somehow get the object...
Yes, things stuck in vacuum hoses are not always as easy to remove as one might think. Trying to push it out with something can be counter-productive, and only get the thing stuck tighter! If you have a second vacuum, you can try sucking it out the way it came in (and risk getting it stuck in the other machine. Or you can try pulling it out, using a wooden stick with a small hook screwed in the end. If you try a piece of bent wire, you must be careful not to perforate the hose. Usually just requires a bit of ingenuity.
Jan 16, 2010 | Vacuums
When I move my bottom lever from Floor to Carpet
I cannot express enough you need to clean your dyson as great as it is its still a vaccum. look underneath at roller, clean out tube wash filter and check to see if vaccum ate something which is stuck inside. I have had mine for 4years and still picks up after 2goldens and kids.
Oct 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Something stuck in my FilterQueen Vacuum
You should be using a broom or mop handle to clear the wand - metal tubing. If you still need help please contact the manufacture at 1-800-344-1840. I did and they were very helpfull, they also sent me a manual at no cost.
May 25, 2007 | Filter Queen Cheetah II Ash - MU305...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
114 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
