Question about Kodak EasyShare DX6490 Digital Camera
I can bearly trun the switch to turn on my camera.
I can bearly turn the switch to turn on my camera. Took me 5 minutes to turn on and I missed the picture I wanted to take. Why has this become so hard to turn?
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, The problem with the DX6490 is it suffers from bad switch assemblies that wear out over time. There is no magic fix other than a new assembly. Not very cost effective due to the market value of the DX6490. The repair costs more than a replacement camera. Post yours on E-Bay for parts and buy a better one.
Best Regards, Russell
Posted on Jan 23, 2013
What makes the wire from the electrict clutch brake when i trun off the mower switch
Are you missing the stop that keeps the pto from turning.
Jul 04, 2016 | Garden
How fix eos 1100d error 70
I took successive shots then I encountered "Error 70". What I did was remove the mmc and the battery and let the camera cool off for 10 minutes. It worked...although I what I want is to really eradicate that Error 70 problem.
Aug 29, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Abs has caused brake lights to fail
Check the wires going to the stoplight switch on the brake pedal. If one of them is broken (gray wire or green wire) it can cause this problem. Or it may be the stoplight switch itself. Let me know what you find.
Jun 24, 2010 | 1997 Ford Econoline
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
2002 Chev Siverado,2500hd duamax dielsel. Changed the two batteries becuase the others died. Now I cannot start the engine. The engine truns over good. The security light flashes.
It sounds like the anti theft pass key's have most it's memory and needs to be reset. Try this, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help
Jun 30, 2009 | 2002 Chevrolet Silverado 2500HD
Screen problems
The LCD screen might be turned off, I accidentaly did this once and all I did was go to menu - set up - reset all and it was fixed.
Aug 07, 2008 | Canon PowerShot A460 Digital Camera
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Kodak EasyShare DX6490 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
