Question about Black & Decker CCS818 Chain Saw
Proper oil for old electric on a electric cord
8 year old electric chain caw on an electric cord. about an18 inch blade.
    Brigadier General:
  • 4,088 Answers
Use regular bar/chain oil available from home centers, hardware stores, and saw dealers. Good luck!
Posted on Jul 03, 2010
How do you remove a plug and chain?and then replace it with a new one?
I spark plug is removed by taking off the electrical push-on cord, taking a ratchet wrench with a socket that fits the spark plug, and then remove it. Replace it with a new one purchased at a hradware store, making sure you set the spark gap properly. On a chainsaw, the blade is removed by one or two nuts that must be loosened with a wrenck or ratchet wrench, which will alllow you to remove the chain, and then replace it with an identical chain, and reverse the process of taking it off. Make sure it does NOT get over tightened or undertightened. It should have about i/2 inch play above the saw blade when you pull the chain. Make sure the two nuts are tightened securely after adjusting the chain tension, and make sure the reservoir for the chain oil is full of oil.
Oct 14, 2014 | Garden
Tip
Brill Razorcut As functionally elegant as a bicycl
Brill Razorcut As functionally elegant as a bicycle, the Brill RazorCut 33 Reel Mower ranks as a highly efficient human-powered machine. It's lightweight and easy to push - with no need for gas, oil or electricity!
MANUFACTURER'S INFORMATION
• Contact-free cutting, precision ground flame hardened bearing mounted blades • Cutting height: 0.7 - 1.8 inches (14-45 mm) easily adjusted, indicators both sides • Large hood protects overhanging flowers and shrubs • Rigid ergonomic handle with foam grip • Mows a 13-inch swath (33 cm) • Cutting technology: Blade cylinder, 5 blades • Weight: 15.21 pounds (6.9 kg) • Wheel diameter: 8 inches • Recommended for areas up to 2150 sq. ft. • Made in Germany • Two year warranty
on May 08, 2009 | Brill Razorcut 38 Push Reel Lawn Mower
What is the spacing size between pins on the electric cord
Measure the pins center to center. There are three common spacings.
1/2 inch, 11/16 inch and 1 1/16 inch..
Appliance cords are available at most hardware stores including Lowes, Home Depot, Menards and even in the electrical departments of many other stores. If you have your old cord it is easy to compare the plugs. There is a 3/8 inch difference between the 11/16" plug and the 1 1/16" so it is easy to see the difference.
Aug 03, 2014 | Faberware 12-55 Cup Coffee Urn
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
How do i reset the timing on 2001 2.7l concorde if the chain was replaced and the timing is off
Did you take pictures while removing the originals? It's always a good habit. Below are the instructions you need to follow. Your own pics are very helpful when doing a big job like this.
  1. Disconnect negative battery (1) cable.
  2. Drain cooling system.
  3. Remove upper intake manifold.
  4. Remove cylinder head covers, crankshaft vibration damper, and timing chain cover.
CAUTION: When aligning timing marks, always rotate engine by turning the crankshaft. Failure to do so will result in valve and/or piston damage.
117014297
  1. Align crankshaft sprocket timing mark to mark on oil pump housing (2). The mark on oil pump housing is 600 ATDC of #1 cylinder.
CAUTION: When the timing chain is removed and the cylinder heads are still installed, DO NOT rotate the camshafts or crankshaft without first locating the proper crankshaft position. Failure to do so will result in valve and/or piston damage.
117016938
  1. Remove primary timing chain tensioner retainer cap (2) and tensioner (1) from right cylinder head.
117016939
  1. Disconnect and remove camshaft position sensor (4) from left cylinder head.
  2. Remove timing chain guide access plugs (3) from cylinder heads.
NOTE: When camshaft sprocket bolts are removed, the camshafts will rotate in a clockwise direction.
  1. Starting with the right camshaft sprocket, remove the sprocket attaching bolts. Remove camshaft damper (1) (if equipped) and sprocket.
  2. Remove left side camshaft sprocket attaching bolts and remove sprocket.
  3. Remove lower chain guide (7) and tensioner arm (8).
  4. Remove the primary timing chain (5).
  5. Remove crankshaft sprocket (6).
INSTALLATION
117016940
  1. Inspect all sprockets (4,9,11) and chain guides (2,5,10). Replace if worn.
  2. For crankshaft sprocket installation procedures Refer to CRANKSHAFT SPROCKET.
  3. If removed, install right and left side short chain guides (11). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
  4. Align crankshaft sprocket timing mark to the mark on oil pump housing (3).
NOTE: Lubricate timing chain and guides with engine oil before installation.
  1. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links (1).
117016941
  1. Lower the primary chain with left side sprocket through the left cylinder head opening.
NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
  1. Loosely position left side camshaft sprocket over camshaft hub.
  2. Align timing (plated) link to the crankshaft sprocket timing mark (3).
  3. Position primary chain onto water pump drive sprocket (10).
  4. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain (8) and loosely position over camshaft hub.
  5. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
  6. Install left side lower chain guide (2) and tensioner arm (5). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
NOTE: Inspect O-ring on chain guide access plugs before installing. Replace O-ring as necessary.
  1. Install chain guide access plugs to cylinder heads. Tighten plugs to 20 Nm (15 ft. lbs.) .
NOTE: To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
117016942
  1. Purge oil from timing chain tensioner using the following procedure:
    1. Place the check ball (2) end of tensioner into the shallow end of Special Tool 8186 (3).
    2. Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
117016943
  1. Reset timing chain tensioner using the following procedure:
    1. Position cylinder plunger (4) into the deeper end of Special Tool 8186 (3).
    2. Apply a downward force until tensioner is reset.
NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball.
CAUTION: Ensure the tensioner is properly reset. The tensioner body (4) must bottom against the top edge of Special Tool 8186 (3). Failure to properly perform the resetting procedure may cause tensioner jamming.
NOTE: Inspect the tensioner O-ring (2) for nicks or cuts and make sure the snap ring (1) is correctly installed, replace as necessary.
117016944
  1. Install the reset chain tensioner (1) into the right cylinder head.
  2. Position tensioner retaining plate (2) and tighten bolts (1) to 12 Nm (105 inch lbs.) .
117016945
  1. Starting at the right cylinder bank, first position the camshaft damper (1) (if equipped) on camshaft hub, then insert a 3/8 square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 inch lbs.) .
  2. Turn the left side camshaft by inserting a 3/8 square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 inch lbs.).
  3. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
117016946
  1. Activate the timing chain tensioner by using a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then release the tensioner arm. Verify the tensioner is activated (extends).
117016947
  1. Install camshaft position sensor (2) and connect electrical connector.
  2. Install the timing chain cover, crankshaft vibration damper, and cylinder head covers.
  3. Install upper intake manifold.
NOTE: After installation of a reset tensioner, engine noise will occur after initial start-up. This noise will normally disappear within 5-10 seconds.
  1. Fill cooling system.
Mar 27, 2013 | 2001 Chrysler Concorde
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
What oil should be used on a McCulloch 16 inch electric chain saw?
It is 2 cycle oil chain saw oil (40 or 50/1) for the engine and bar oil for the blade.
Sep 25, 2010 | McCulloch Garden
Where do i purchase chain saw oil for electric chain saw
Hi
It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership.
Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine.
The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up.
The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also:
http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed.
HF
Feb 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
Black & Decker CCS818 Chain Saw Logo
123 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
