I HAVE IR 4570 WITH PROBLEM E0000000-0001 - Office Equipment & Supplies
  • 1,326 Answers
E0000-001 means that the fixing unit is at the wrong temperture. Did you have a power problem recently? If so, you mat be able to rest the code. You have to get into service mode > press "*" then "2&8" at the same time then "*". the display will change > press "copier" then "funcation" then "clr" then "err" then pres the "OK" in the bottom right corner and then turn then main power off then back on. If the code can be cleared, you are back to work. If not you will have to have the Upper fixing unit or fuser unit replaced... Good Luck
Posted on Jul 04, 2010
Ir 4570 print half side print is good and half side print is light how to solve
This problem may be caused by several different issues. It may be a dirty laser unit, a bad developing unit or a dirty or bad CCD unit. All of these will require an experienced technician to troubleshoot and clean or replace. I recommend you call an authorized Canon dealership.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
Jan 23, 2017 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Help what is this code e000191-000
Jam Code 205 in Ir-4570 solved by replacing sensor PS-59 Arm
Oct 08, 2012 | Canon Imagerunner 4570 Copier
From where can i get genuine canon ir 4570 fuser film
Hello
The genuine parts is available to authorized Cannon Service Center or you can buy online from here http://www.precisionroller.com/fixing-film-assemblies---units-for-canon-imagerunner-4570/details_35006.html
Hope this helps
Jan 26, 2011 | Office Equipment & Supplies
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
348 people viewed this question
k24674
jasbo
jasbo
