Question about Kenmore Elite 45986 Front Load Washer
My sister pours a lot of liquid softener into our Kenmore Elite front load dispenser. I said to only use 1/4 cup as recommended. Will using too much fabric softener cause problems?
  • 259 Answers
YES!! This machine uses an average of 14 gallons of water per load as compared to 40 gallons for a top load!! Less water means less detergents!! Excess detergent and softener can create build up withing the machine that will cause unpleasant odors and eventually rear bearing failure.
Posted on Jul 03, 2010
Frigidare top loading washing machine, 1995 model # GLMS174SAS4
I believe the softener is dispensed through centrifugal force when the machine is in the high speed spin after draining and before filling for the rinse cycle. I had the same issue on another machine. Use very hot water and a washcloth to clean out the softener cup. When adding softener at the beginning of the load, only add the recommended amount and then fill the remainder of the cup with water.
Mar 06, 2015 | Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
Can i use liquid fabric softener in this machine?
If your Admiral washer has no liquid fabric softener dispenser on top of the agitator, the instructions say to dilute the recommended amount of softener with 1/2 to 1 cup of warm water and add it to the rinse cycle. The manual also states that you should be careful not to pour it directly on the clothes or on the tub, only into the water.
Jul 07, 2010 | Admiral 32 cu. ft. Washer
The Liquid Fabric Softner dosn't dispense completely. Approximately 1/4 of it is left in the chamber.
the problem is that the hole that drains the chamber is partially blocked with dry fabric softener. pour a cup of viinegar in to the dispenser and do the wash using the hot water cycle and no clothes. this will clean it for u
use white vinegar if u have it or apple cider vinegar
Aug 17, 2009 | Kenmore HE2 Plus Front Load Washer
Softener tray filling with water
open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
Sep 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
Aug 21, 2008 | Kenmore Elite 45986 Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
HE washing machine
As you look at your dispenser. The Left compartment is for Detergent. The Right Front compartment is for the Fabric Softener Liquid. The Right Rear compartment is for Chlorine Bleach.
Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
175 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
