Question about Kodak EasyShare Z1275 Digital Camera
My 71275 is stuck in the full zoom position and won't stay on...
My 71275 is stuck in the full zoom position, and when I press the On/off button it flashes on for a second then goes off again. Zoom does not move.
Batteries are fresh. When the camera is connected to the computer, the computer recognizes the camera but cannot retrieve any information.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 03, 2010
  • cristian411 Mar 12, 2011
    Number#4 worked like a charm, I can't thank you enough!!!
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
I have a JVC Everio digital camcorder and it's stuck on 32x zoom and won't zoom back in. I've taken the battery off and pressed the reset button but it seems to make no difference. What can I...
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 13, 2011 | JVC Everio GZ-MG21 Camcorder
I have a minolta MD lens 35-70mm f3.5 that is stuck at 70mm. how do i get it unstuck?
Hi!
Is your lens having a "macro 1:4 - 1:7" green sign near the "70"? If it does it may be stuck in the macro position... ? To put it back into the normal "35-70" zooming position just press the little black and greenish button on the lens, turning the zoom anti-clockwise.
Well... i'm Italian and tonight my english is particularly stuck.. But I hope this could help you!
Let me know, cheers :)
Emi
Feb 02, 2011 | Cameras
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Nikon coolpix 2200 zoom
Based on your description, it certainly sounds like the zoom button is stuck or shorted. If you're comfortable with taking it apart, I'd try getting to the zoom electronics and see if there's any noticeable damage. Whenever I try something like this, I like to see how much damage I could cause first. eBay has sold this item for less than $50 with shipping (just in case you break something). You can also look there for parts cameras -- one listed for $10 with free shipping that might give you what you need.
Aug 21, 2007 | Nikon Coolpix 2200 Digital Camera
Nikon coolpix 2200 zoom mechanism
If the lens assy is not responding to zoom buttons then the camera is in confusion mode due to a sensor being blocked or defective. Normally it would go thru a startup cycle to initialise position of various parts in the lens assy and give back control to you but in your case it is not getting that signal and in your case I would bet on the end sensor.
Nov 08, 2006 | Nikon Coolpix 2200 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
459 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
