Question about Car Audio & Video
Can you describe how to put R134 into a 1999 chevy malibu I have been told to look for the "blue Cap" but cannot seem to locate it
5 Suggested Answers
  • 82 Answers
SOURCE: where is the horn located in a chevy malibu 997
front of car right hand side
Posted on Apr 06, 2010
  • 753 Answers
SOURCE: 2005 Chevy Malibu gas cap tightened, chk eng still on.
It needs to be reset or cleared this can be done at your local AutoZone or local repair facility.
Posted on Jul 24, 2010
Transdoc
  • 829 Answers
SOURCE: I found the transmission fill
There is no dip stick. There is a 7/16 check plug just under the passenger side axle.The transmission must be warm and the engine idling in park to check. This tough to do without a lift.Fluid will drip out of hole when full.
Posted on Feb 01, 2011
  • 9 Answers
SOURCE: Cannot locate horn for a 2002 Chevy Malibu
the horn is behind the passenger front fender. right in front of the tire. you need to remove the dust cover to gain access to the horn(s).
the picture was shot from underneath the car. you can not get to the horn(s) any other way.
Posted on May 25, 2015
Where is the cap to recharge the ac for my 2008 chevy Malibu LTZ 6 cylinder
First pop the engine cover off. You are looking for a small cap with an "L" on it. This stands for Low Pressure. Most of the time they are blue. Avoid the "H" (High Pressure). The lines are typically silver in color.
May 01, 2015 | 2008 Chevrolet Malibu LTZ
Where is the radiator on a 99 Chevy Malibu?
Their is no radiator cap that goes directly into radiator. if you do plan on putting barr's leak in it just put it in the coolent tank on the passenger side that is the only way.
Feb 05, 2013 | 1999 Chevrolet Malibu
Where do you put the brake fluid in a 1998 Chevy malilbu
The brake fluid goes in a reservoir on top of the master cyclinder inside the firewall under the hood.
Open the hood of your 1998 Chevy Malibu and locate the brake fluid reservoir. On a 1998 Malibu, it's located on the driver's side closest to the front windshield. Open the reservoir tank and place the cap in a safe place where it won't get lost. Fill it to the fill line and not above then replace the cap and your done. Now you need to figure out where the brake fluid is going since this is a closed system and if it is low then your brakes are getting worn and more fluid is accumulating in the lines due to more travel of the brake cyclinders or you have a leak. The master cylinder should look like this picture, if you find this helpful, a vote with the thumbs up would be appreciated
Jul 15, 2011 | 1998 Chevrolet Malibu
Yes i have a 2002 malibu but cant find the transmission dipstick where did the hide it plz help
There is no dipstick on the Malibu transmission. To correctly check fluid level, you must locate the filler cap and the check plug on the transmission. The filler cap is a red cap located on the drivers side of the transmission between the air filter box and exhaust crossover pipe, almost under the crossover pipe. The check plug is located on the passengers side of the transmission, just behind where the axle connects to the transmission. It has an 11mm head and can be seen if you lay in front of the passengers front tire, look about 3 inches above the transmission pan. Once you have located these, warm the transmission to normal operating temperature, and with the car running, transmission in park, and the car sitting level, slowley remove the check plug, have a drain pan under the plug in case any fluid comes out. There should be very little fluid coming out, if there is none coming out re-install the plug, remove the filler cap and put 1/2 quart of fluid in, now run the transmission thru all the gears and back to park. Put the drain pan under the plug and remove the plug, if it is overfull, let it drain until it stops, if it still doesn't have fluid coming out, add 1/2 quart at a time until it does, following the above procedure. Make sure you let any excess fluid drain out and re-install the plug. As noted above, make sure the car is running while checking the fluid. I know it seems complicated but it isn't as bad as it sounds. This same procedure applies to all Chevy Malibus from about 1997 until 2004 if I'm not mistaken. thanks to carjunkie
Jun 02, 2011 | 2002 Chevrolet Malibu
It needs to be reset probably has a p0440 code in the computer.
Jul 24, 2010 | 2005 Chevrolet Malibu
FACING THE CAR, WHERE IS THE EXACT LOCATION TO ADD FREON TO A 1997 CHEVY MALIBU. WE FOUND A RED CAP BUT UNDERSTAND THIS IS NOT WHERE YOU SHOULD ADD. HELP .....
The low pressure refrigerant port is near the firewall2.gif, just after the receiver/dryer. You'll need a gauge and preferably an ac test manifold. You can use the manifold to add refrigerant up to the point where the system maintains the pressure level in the green area. There should be a blue cap on the low pressure valve.
I believe your malibu take's 12 ounce's of R134, don't over charger the system. You'll blow O rings and worst kill the A/C compressor.
Good luck and hope this helps. Here is a link for A/C recharging. http://www.geocities.com/vantaray/air_conditioning.htm
Aug 19, 2009 | 1997 Chevrolet Malibu
Check engine light
it is grounding , wires went direct connection . and check the fuse box or fussiblelink .
Jul 10, 2009 | 2007 Chevrolet Malibu SS Sedan New Cars
Re-filling tranny fluid in a 2005 Chevy Malibu
There should be a fill cap locate drivers side down on top the drive axle. Check your book or call auto parts store for capicity
Apr 10, 2009 | 2005 Chevrolet Malibu
How to Recharge A/C on a 2001 Chevy Malibu
The low pressure port is located on the passenger side next to the fire wall. It will have a blue cap.
Sep 22, 2008 | 2001 Chevrolet Malibu
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
