Question about Select Jazzy Used Electric Wheelchair
I have a jazzy 1120 and it got wet from rain. when I pushed the power button the lights falashed and nothing happened. I dried the controller and waited a few days now when you push the power button then ligths will fkash but when you push the power button a couple of times and really hard the lights will go off and the speed lights will come on to the first bar then yuou can push the horn button it will blow but the red light will come on on the top for the charge lights. Do you have any suggeetions it has been about a week and I alson took the controller apart and dried it out. HELP
  • Select Master
  • 15,667 Answers
You have a serious problem. When something gets wet and it has power to it then the power tends to corrode things. The control board has contacts inside it that are subject to being corroded and also the switches could have been damaged too. Unfortunately the controller is really expensive. http://www.monsterscooterparts.com/jazzy1120.html
Posted on Jul 03, 2010
Jazzy 1120
"Cuts out" is not enough info. Check all connections for tightness, full battery and light codes.
Apr 29, 2013 | Pride Mobility Products Used Jazzy...
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
Apr 03, 2013 | Pride Mobility Products Used Jazzy...
Jazzy 1120 changing controller type?
The 1120 usually comes with either of 3 different controllers: Pilot, Remote Plus or Europa. They function similarly but the setups are a bit different.
Apr 02, 2013 | Pride Mobility Products Used Jazzy...
My dads Jazzy 600 got wet and now wont do anything. no lights at all. what can I do- he needs it daily and we are on fixed income?
If medicare paid for Dad's chair then contact Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare didn't pay for Dad's chair then the cost of a refurbed joystick is still very high about $700 and if the joystick got wet then he'll need a new or refurbed one. Sorry Hope this helps
Apr 02, 2011 | Pride Mobility Products Used Jazzy...
Jazzy 610 got wet. controller lights blink
Electricity and water don't mix. Allow the controller to dry out for several days. Even if it looks dry, water may have collected inside and fried something.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Aug 06, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Jazzy battery lights will not light and the car will not move.
check there is power in the batteries, if so check all wiring for breaks loose fittings, fuse trip switch etc, failing that it may well be the controller, hope it is not that as they are not cheap.
Jun 20, 2010 | Pride Mobility Products Used Jazzy...
Coolpix L1 that won't take a picture after getting wet
try dismantling you will find a gooey substance in a microchip. try removing it.i hope it works
Sep 12, 2009 | Cameras
Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Apr 28, 2009 | Pride Mobility Products Used Jazzy...
Select Jazzy Used Electric Wheelchair Logo
55 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
