Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Help with installing or setting up Jandy OneTouch PCB Subassembly
I installed the Jandy OneTouch PCB Subassembly Display, part # R0550700 and it is simple 4 low voltage wires color coded and the Display has matching color codes. It lit up put all I got was (at the top) Firmware Rev B13 and then small xxxxx the rest of the screen down. I tried the reset button and I tried turning on and off the breakers outside still the same. The outside controller (by Jacuzzi) is and always has been working (before the change and after the change) and those wires go into the main circuit board (outside by pool equipment) the same as the ones from the new Display. So I do not know if there is some combination of the keypad buttons that should be pressed to get to the main menu or out of the “Firmware Rev B13 and then small xxxxx the rest of the screen down” to a main menu? Can you provide any help? There are some differences in the boards and similarities such as the new board has PCB7750F and the old PCB7750C the new has REV M 39/09 and the old REV D4601on both Multiple Control Panel S. And hand written on the old back is J1 R with a circle around it.
I figured this was just a newer model since mine was installed July 2003 and I am not sure of the manufacture date. Is there an install manual to refer to online? I just started looking but no luck so far. I did not leave the new one hooked up very long for fear it might get damaged maybe 30 seconds to one minute. All the lights came on just the main menu screen never came up. Maybe I should hook it up for a few minutes to set itself?
Before I bought this I did have a technician come out and they told me the Display board was bad and to order one. Any help is greatly appreciated.
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Contact jandy they will tell you if it is compatible
Posted on Jan 30, 2016
3 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
SOURCE: Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
Posted on Nov 11, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
I upgraded my Jandy RS controller to run Jandy epumps and installed a new Pentair Mastertemp 400HD heater. Prior to connecting the pool heater thermostat all worked perfect. all instructions stated to...
bad info firemans switch is continuity only if hooked up to firemans switch run new wire from each end of firemans switch to pins 1 and 2 of long plug along top of PCB board make sure to read inside schematic for dip switch positions firemans switch to control heater on and off you will have to turn heater all the way up max setting for temp
Jan 16, 2015 | Jandy AquaLink RS OneTouch Wired White...
What can I do to use a PCB#6474G to replace a broken PCB#8124A?
yes the G is just a newer board go to set up and reprogram all your auxs just re assign them
Jun 15, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
Erase a program jandy aqualink rs8
set up then to program highlight program and delete
Aug 04, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
How to change a temperature sensor in a jandy lite2 pool heater
remove top and right side covers till you get to the top of the exchange on rightside by plumbing two black wires go into sensor remove bolt and install new one two black wires go to pcb board
Jun 02, 2012 | Jandy Pool & Spa
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Firmware screen
shorted wire to controller or plugs if all ok bad pcb board
Jun 12, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
264 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
