Question about Frigidaire FRT15B3A Top Freezer Refrigerator
The top rack of my frigidaire FFU1724DW5 does not get as cold as the other racks.
    President:
  • 1,891 Answers
Prob is poor door sealing of low ref charge .. this would cause the prob . ck door seal first . then the ref charge .. ,, mm
Posted on Jul 04, 2010
Frigidaire ultra quiet iii top rack not cleaning - bottom rack is great.
Use a magic eraser.
Also there is an excellent product from Home Depot, Krud Kutter.
Also googone, not goof off ( Goof Off is a stronger , more potent chemical and Goo Gone isn't as dangerous but very effective and works great!)
Goo Gone is at almost every store.
If these don't work, let me know.
Thanks and good luck !
Jan 02, 2015 | Frigidaire Dishwashers
Need diagram to reinstall top rack frigidaire dishwasher model FDB520RHB2
Frigidaire usually has free manual downloads on their web site. The manual should have diagrams for repairs.
Oct 27, 2014 | Dishwashers
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My top 2 racks frost up and the bottom 2 barely feel cold
If the condenser coil (in the back) is clean ,it is probably that the unit is low on refrigerant(freon) which means there's a leak , and before recharge it is has to be repair(the leak).
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
How does the rack come out of the freezer to adjust
there should be a plastic clip between the rack and left side of the freezer remove the clip then push the rack to the left real hard then the right side should come out raise the right side up and remove rack
Jul 12, 2009 | Frigidaire FRT15B3A Top Freezer...
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
How do I use the dryer rack in the Frigidaire Infinity gas dryer. I can insert it but what do I do to keep the drum from rotating and tossing the rack aroung?
Do you have a lint filter slot inside of your dryer or on the top? Our rack in ours mounts into the lint filter slot and the drum turns around it and does not turn the rack. If you have a lift filter that is on top of the unit the rack may mount into the back panel allowing the drum to turn around it.
Mar 03, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
