Question about Cameras
On switching on the camera after about 30 sec. The " change batters " comes up even with new batteries !!!!
  • 6,826 Answers
In some cameras AA batteries are not all created equal. Voltages of different types of batteries vary, and may trigger this error on the camera. Make sure you read the instructions and use the correct battery type, Alkaline, NiMH, or even Li-Ion depending on your camera's specific instructions.
Posted on Jul 03, 2010
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Sep 20, 2014 | Canon EOS-20D Digital Camera
SONY DSC-W220/B My camera is displaying a message E:91:01 and will not flash. What do I do?
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this does not work do this:
THE MASTER RESET
(1) remove the battery pack
(2) press and hold the power button for 30 sec
(3) after put the battery back do not turn it on for 1 min
(4) turn on
May 27, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
My box is stuck on language
Disconnect power for 30 secs then plug back in. language screen will come up again press OK and it will take you to installation.
If you have a mobile with camera you can check the remote by pointing at camera lens and pressing a button, you will see the IR light flashing, if it doesn't change the batteries.
Sep 21, 2009 | StarTech.com StarView 2-port KVM Switch
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Doesn't recognize new batteries - no photo function
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Mar 30, 2009 | Canon PowerShot S2 IS Digital Camera
The main batter will not hold its charge when left in the camera.
After 12 months use camera batteries will not hold a true charge, but they can still be used for clocks, or remotes. Buy new ones. We all have the same problem.
Mar 08, 2009 | Sony Alpha DSLR-A100 Digital Camera
Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Aug 08, 2008 | Canon PowerShot A430 Digital Camera
Battery runs down fast.
hello there....well its quite simple...
how old is your phone ?
i am assuming its an old phone so it is time to change the battery...you will see that batter is slightly puffed or out of shape ...in that case you should immediately change it
if its a new phone....then check if blue tooth is on or off....it should be off....and if you use the phone a lot then also the batter will run out in 3 hrs and 30 minutes of talk time...playing music as well as keeping the camera on for a long time will drain the batter
so it depends on how you use it ....if you have more question we will take it from there
Hope this help
Cheers
Aug 05, 2008 | Nokia N70 Cellular Phone
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
