Question about Dryers
I hava Kenmore Dryer model 417 and it spins fine. But the heating element doesnt work at all. This just happened after I jhad To replace my washer. These units were stacked. So maybe something is looose? Any thoughts
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerI hava Kenmore Dryer model 417 and it spins fine. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
dryer is electric2_bing.gifDryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 04, 2010
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
The heating element in the dryer isn't heating up.
there is no reset button if your model starts with 417 it probally is the element
Jan 10, 2010 | Washing Machines
No Heat on Kenmore Gas Dryer Model 417
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further, please let me know.
Thanks
Vic
May 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer doesn't work
putzer, I give you credit, this is not the easiest job on this model. If this is a 417 model, on the housing where the element sits inside you have a high limit thermal fuse and control thermostat. According to the diagram I have the high limit should have a black and orange/black wire coming from it. These diagrams can be wrong however. Remove the wires from it and test it with a meter, should show continuity. If it is open, no heat. Catriver...post back.
Apr 23, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
232 people viewed this question
Top Dryers Experts
