Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
Cycle runs but dishes are still dirty. No water.
Ran a full cycle but dishes were still dirty. No water appears to be coming into the dishwasher but a very small amount of water was in the bottom. Sounds like a motor or pump is trying to work and then stops and you can smell a burning smell.
  • 53 Answers
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Posted on Jul 03, 2010
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
My whirlpool dishwasher is not cleaning dishes all the way. some are still dirty after a full cycle
Do you live in a region that has hard water? See this map to find out.
http://www.citriclean.net/why-citriclean/
Mar 09, 2013 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Dishes recently started feeling gritty after cycle is complete. I cleaned the dishwasher, ran a full cycle w/o dishes, and added JetDry, which has helped some, but problem persists. The unit occasionally...
It is possible your dishwasher is dirty. I have found this wonderful product called "Dishwasher Magic" It cleans rust, midew and scaling from deep inside your washer leaving it like new. Try it it's a wonderful product
Nov 18, 2009 | Refrigerators
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishes still dirty
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine.
Apr 03, 2009 | Dishwashers
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
236 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
