Question about Toshiba 50H82 50" Rear Projection Television
50h82 red convergence ic replacement
Since I'm having problems only with the veritcal adjustement of the red (the cross moves right & left but not up & down)
I decided to replace only one of ic's. Just to be sure, can someone point me to the right direction? do I nedd to change the Q751(RVBVGV) or the Q752 (RHBHGH).
I don't want to desolder/solder twice :)
Also, if someone can tell me how to test the part Q783 p/n: 23202037 it will be very helpfull :)
Thanks
  • Anonymous May 18, 2009
    I have the same problem with the red convergence not matching vertically. Is this something I can easily fix or will I have to get a repair person? Also.... is this expensive to repair?
  • 4,234 Answers
Q783 is a 2SJ512 (FET) with part number 23205037. These are not the easiest to test. If you suspect that it is bad, just replace it. It costs $2.48. I only have a listing for one convergence IC (STK-392-110), but if there are 2, replace the one labeled RVBVGV or just swap the two to see if the convergence shifts from vertical to horizontal.
Keep us posted.
Dan
Posted on Apr 17, 2008
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba 42wh46p convergence problem
Yes Replace Both STKs also CK all low ohm resistors.
Feb 15, 2009 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Blurry shadows in red and teal.
Just click below for convergence repair kit;
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
When this happens it means the convergance Ic's have failed ( STK392-110's) they will need replacing then the cross hairs will move again
Feb 07, 2008 | Panasonic PT-56HX40 56" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
TZ-55V61 Convergence
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Aug 22, 2006 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
