Question about Canon PowerShot A520 Digital Camera
My doughters seemed to drop the camera onto a grass field, while the camera was opened, now the camera cannot be closed properly nor opened. I took out a small straw of grass from the lense, but something seems to be stuck there. Is it worth taking it to a pro for fixing, or just look for a new camera, since this one was good but a bit out of date.?????
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 03, 2010
My nikon d40 camera barely dropped on the carpet and now when i take the pictures they are all dark even with flash on. please help me
ok, lets try a few things...First, make sure the knobs, buttons, settings, etc have not moved from the drop or put them back where they belong if they did move. I would suggest doing a "Green button"
reset. Turn on your camera, press and hold the two buttons that have the "green" dot next to them, release them after you see the display flash( a few seconds). this resets the camera to the factory defaults on most adjustments, enough to get it working correctly if nothing is actually broken. Once you have done that, make sure the lens is properly mounted and locked in position. check the lens to see if you can focus and zoom it by hand, this will tell you if the lens is "basically" ok. we need to see if the aperture is closing down when the picture is taken. to do this, point the camera toward you so you can see inside the front end of the lens. you should be viewing the camera like it is in the picture in the top of this post, looking at the front. watch closely inside the lens and take a picture of yourself(without flash!!). you should have seen the aperture close down and then open back up. If you saw this then the camera is working the aperture correctly. if all that is working we need to check the speed and fstop settings of the camera. a quick way to do this is as follows. I'm assuming you know how to set your camera on Manual. Set the iso at 200, go outside, on a sunny day and take a meter reading off the grass in the lawn. the meter should read fairly close to 1/200 (1/250)with your aperture set at f16. If you get this reading then your meter is working ok. next set your camera on manual, and adjust the shutter speeds from slow to fast. take a picture at slow and see if the shutter opens and closes slowly, then take a shot at fast speed to see if the speed of the shutter is "following" your commands, we are looking to see that there is a noticeable difference between "real Slow" and Real fast". if so, now we know that the shutter is working properly. if any of these don't seem right you will need to dig deeper to find the problem or get it serviced. Hopefully the lens bumped out of position when it fell, that would be the easiest to fix, but, that is all i can think of for now. Good luck, Worm1855.
Jan 17, 2011 | Nikon D40x Digital Camera
Lifetime Portable Basketball System- The pole are stuck.
Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
Jul 04, 2010 | Lifetime 3819 Impact 44" Basketball...
Err 99 with lens attached
sorry to hear about your problem. What I would test first is the diaphragm of the lens.
Set the camera to the AV mode, install the lens then set the camera to a diaphragm setting around F-22.
Press the depth of field preview button while you're looking through the front of the lens. you should see the diaphragm open and close each time you press the depth of field preview button. If the diaphragm fails to open and close or if it opens and closes erratically that would indicate a diaphragm failure and could result in the error code and the mirror flopping. if the diaphragm proves to work properly the problem can be with your image stabilizing unit. Does have a three year warranty on all of their lenses if you haven't dropped the lens and it hasn't been subjected to moisture and is within the three-year time. For the warranty you may be eligible to have Canon repair it for free I would suggest contacting can directly have your serial number ready and proof of purchase. Contact me directly if I can be of any help. Thank you Dave@ advance camera.com
Jan 13, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My daughter dropped her sister's Nikon Coolpix S560 in the sanddunes today with the lens open. It still took pictures after that but the lens wouldn't close. Now it opens and closes and makes a grating...
It seems that some sand particles are lodged between the lens casing and the camera's body. and when it finds that there is resistence in moving the lens, it shuts down. Use somethig that sucks, like the vacuum cleaner to **** the sand particles out. Do not blow, else the sand will go further in.
Aug 06, 2009 | Cameras
The camera fell off a desk onto a carpeted floor while uploading pics to the computer. Now the lens will not close properly and I keep getting a "lens error" message. Nothing looks cracked. Can this be...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon PowerShot SD600 Digital Camera
Count the number of open and closed order status per owner
My suggestion is to use a Pivot Table.  Follow these instructions:
Click on column A1 - then in the menu bar click DATA > Pivot Table and Pivot Chart Report.
Click NEXT on step 1 of pivot table wizard.
For step two you will want to highlight all of the data on your sheet.  then click next.
Choose NEW WORKSHEET for step 3 of the pivot table wizard and click finish.
Once the Pivot Table sheet opens, drag the STATUS field into the top left corner of the pivot table view, where "drop column fields" and "drop row fields" meet.  Next drop another instance of the STATUS field into the "drop row fields here" column.  And lastly drop the OWNER field into the "drop column fields here" section.  You should now be viewing a report showing you exactly what you were looking for.
Regards,
Joe
May 07, 2009 | Microsoft Excel for PC
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
Lines on screen
Hi, I have the same problem with my sony DSC-S700. I think someone drop it, and it took pictures with horizontal line specially outdoor. I noticed that the lens shutter does'nt open and close. All I did was to tap on the lens several times and everythings back to normal. I so happy my camera is working again. Thanks to your idea. Brenton
Sep 24, 2007 | Kodak EasyShare Z612 Digital Camera
Canon PowerShot A520 Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
