Question about Hayward Navigator Pool Cleaner
Not moving around the pool and nothing trapped inside
  • 640 Answers
With these automatic pool cleaners, if there are no blockages, it is usually a problem with the water flow. Use the water flow gauge and check to make sure that you are getting adequate pressure from the returns. I would also check the wings and shoes to make sure that they are not worn.
Posted on Jul 22, 2010
Why won't it sink to the bottom?
Air trapped in the unit. They do not float unless air is trapped. Turn upside down under water to relieve trapped air.
Jun 23, 2015 | Zodiac Baracuda G2 - In Ground Suction...
How to rebuild a 1 1/2 HP pool pump
Have you checked all the rubber seals. I know mine would not run because the large rubber sead around the impeller housing went bad. While getting the part , I was told of a paper gasket at the motor and impeller housing, got that, the round rubber seal around the trap was cracked and sucked air as well. When I got inside the impeller was clogged with small acorn beads from the oak tree from three years of that. They were baby acorn about the size of a bb that filled the impeller holes. It could be a host of problems like mine. Best thing to do if you dont know how to do all this stuff is take it to a pool place and let them do it.
Jan 30, 2015 | Pool & Spa
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Low flow keeps alarming
the manual doesn't tell u but the obvious solution is debris trapped in the filter that water flows from the pool to the pump. The one screwed into the pool liner. Unscrew the Blue cover , the one on the inside of the pool, and u will be surprised how much junk gets trapped in there, clean it out once and week and after vacuuming the pool
Jun 04, 2011 | Intex '10 Saltwater System Pool...
Too much suction does not move around pool seems to just **** to the bottom. have cleaned all leaves out of filter. makes the water exit area to the filter vibrate
It sounds like you could have an obstruction in the hose. Check the entire length of hose from the pool filter to the pool cleaner and make sure that nothing is causing a back up of pressure. If you don't see anything, it could be that this pool cleaners not compatible with a pool pump as strong as the one that you have.
Feb 15, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac G4 will not move
Verify nothing is stuck inside the vacuum. Try adjusting your intake valves to reduce flow from your skimmer(s) and increase flow from the vacuum. Also, how old is the diaphragm inside the vacuum? Inspect it for rips and tears. Also, check the flex hose for rips and tears as well.
Aug 04, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
It is sucking but it won't move around in the pool
Inspect the diaphragm inside, check for deformity and/or debris. If it is deformed (the edges of the **** should be very close together and parallel), you may need to replace it.
Jun 11, 2009 | Zodiac Pacer Pool Cleaner
Hayward Navigator Pool Cleaner Logo
198 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
