Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yardman mtd 38 in cut the mower is slipping in gear as if the rear end would be messed up I have changed the rear end out completely & its still doing it what else could it be that may need replacing?
moretons
  • 155 Answers
SOURCE: I need an owners manule for an old mtd yardman 6.5
try the mtd website
Posted on Jul 25, 2009
cjrepairs
  • 60 Answers
SOURCE: mtd yardman mower== took it tto local repair man
chances are he over tensioned the brake spring nut there is a specfic measurement from end to end of spring I know on the Castle garden it its 47.5-49.5mm. too much can damage the brake.Its more than annoying when repairs come back like this.
Posted on Aug 12, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: MTD Yard machine Lawn mower. Slips and jerks while
SOUNDS LIKE THE INPUT SHAFT ON THE TRANS IS STRIPED OUT
Posted on Nov 06, 2009
Did you find the problem with the rider slipping when going down hills, I have one that is doing the same thing, I changed the belts, but that still did not help. It does not do it going up hils in forward gear, or going up or down in reverse. Thanks Bob
Posted on Aug 02, 2010
How to change a Yardman M.T.d. transmission drive belt diagram on 46" cut?
You can go to the Yardman website and download the service/owner's manual.
Aug 18, 2014 | Garden
I have a yard man 13AH762F752 How do I know what size my deck is I thought it was a 38" and bought v-type belt and it is to shore so how do I find out my deck size?
If you have a single idler pulley you should have a 38" deck. If the deck has two idlers, then you must have a 42"deck. You should be able to approximate by measuring. This is the "cutting" width, not overall width. Two things might have happened. You didn't get the right belt, or you haven't routed it properly. Here is a link to the Yardman web site to download your manual if you don't have it. It appears that the 38" deck requires a longer belt than the 42" deck. http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10201
Jun 18, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
2007 mtd yardman model13ac762f755
Check the main pully and also the two spindle pully's. Sometimes the pully's split and you won't really know unless you have a real good look. Also, the belt may be worn to a point where it won't turn in the pully's when the tension is on.
Sep 21, 2009 | Garden
Farmal C won't go in gear while running, grinds
I have one that has the same problem,I split tractor to repace rear main clutch an preasure plate,my throw out bearing was bad and the shaft was rusted and would not let the throw bearing go all the way in to the preasure plate
Jun 24, 2009 | Farmall Tractor C ,super Av, Complete...
My transmission belt slipped on my yardman mtd 42'' garden tractor. How do I relieve the tension on pulleys to slip it back on?
the tension on rear end you can jack it up in the rear & spin the right tire to get it back on & make sure the brake isn't on
Jun 13, 2009 | Garden
Mtd yardman mower== took it tto local repair man to fix for no brake and shifting hard. Now I have a brake but have lost the top 4-5 speeds. and it acts like it is going to slip out of gear. I have been a...
Apr 26, 2009 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
80 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
