Question about HP LaserJet P3005dn Printer
Print out very light
The print seems to be working ok.
Its went thru the self test.
I did replace the scanner assembly but it did not solved the problem.
Any suggestions?
  • 734 Answers
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
When i print red, i get pink
you might need to replace the laser cartrige, If its not that please tell me what you are trying to print (red picture or red text/writing)
-DF
Jun 08, 2012 | Samsung CLP320 AllInOne Laser Printer
I hooked up my 9 year old HP DeskJet 1220 C PS to a new iMac and MacMini and did a test print with the latest Drivers and it work OK. I went to use it the next day, it made a clunky noise and stopped -...
wow.. that is the timing belt and is threaded thru the back side of the ink cartridge assy and is attached at the right and left sides of the carriage assembly.. no way to explain that one.. printer has to be taken apart to the frame and the carriage assembly removed the timing strip re threaded thru the back side and the timing photo sensor and reinstalled.. the timing strip will only go no one way...
Mar 31, 2010 | HP DeskJet 1220c InkJet Printer
Every time I try to print the paper jams. All the paper has been removed, turned it off, still jamming
Found this on the Web, hope it helps you.
If you find this helpful, pls rate me.
Turn your printer off for about 10 seconds, remove the printer cable and then turn the printer back-on. Does only the Green Power Light come on solid [not blinking], as would be normal, or does the Red Error Light also come on? If only the green power light comes on, then try running your printers self-test page, directly from the printer. On most epson printers you can usually run an self-test page to determine whether a problem comes from the printer itself, or possibly from your computer system. Of course if there are actually any red error lights/leds, already showing on your printer, that would indicate that there is already a problem in your printer. Not all epson printers are always the same, but the following information applies to most models. If this self-test does not actually work on your particular printer, then you should refer to your "User's Manual/Owners Manual" for the correct procedure on how to run your printers self-test page. First unhook/unplug the printer cable from the back or side of the printer. Leave the power cord still plugged in to the wall and leave the paper loaded, as normal. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or information that may still have been in the printers system, from when the computer was previously connected. Normally [on most models], you turn the printer off and then you simply reach over and hold-in on the paper button, while you reach over and turn the power button back on, as normal. Continue to hold in on the paper button for about 3 to 5 seconds, but release the power button after turning your printer on. Release the paper button once you can hear and see the printer starting to initialize and start to pull-in a piece of paper. The printer will normally print out the self-test copy, which will also have a nozzle test on it. If that test fails, or cannot actually be ran because the "Red Error Lights" come on, then you know that there is an actual problem in the printer. Depending on the combination of which lights are on SOLID, or FLASHING or OFF, will actually indicate the possible service error condition. Be sure and let us know if you recently had to remove any bad paper jams, by yanking out the paper with force, especially towards the rear of the printer, in the backwards direction. There is a common problem when you get a constant jam condition, or paper won't feed in correctly after a bad jam was removed, or even when the printer or your computer thinks that the paper has not been correctly loaded. If that is the case, then its possible that a part was unhooked/unseated or even damaged, causing a possible constant paper jam condition. If you did have a bad jam, prior to the paper feeding problem, then let us know and we can try to help you further...ON THE OTHER HAND: If everything is working correctly in the printers Paper Feed Assembly, Carriage Assembly/Cartridge Assembly and the Printhead Assembly, then the self-test copy should be printed out and correctly fed thru the printer. If the self-test page prints out correctly and the nozzle test looks ok, then that indicates that your printer thinks it is working normally [as far as the self-test goes].
Thanks and Good Luck.
Jan 25, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Red light when printing
It sounds like your problem is actually in your PC or Computer System. Possibly in your computers software, or in the internal settings inside your computer. I only work on the printers and you may need a computer trained technician. As this is a PRINTER REPAIR SITE, you may not find the help you really need. I do hope that someone that reads your message, knows about computer settings and problems and can help you further. If not, you might want to search for a computer repair site, for possible help...Just in case you want to be sure its not your printer, you can run a STAND ALONE PRINTER TEST, with your printer not connected to your PC or Computer System. Unhook the "printer cable" from the back of the printer. The power cord would still be plugged in to the wall and paper would be loaded normally. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or INFORMATION that may still have been in the printers system, from when the PC was previously connected. Now reach over and turn the printer on as normal. The printer should come on and go to a normal READY CONDITION, with no ERROR LIGHTS on. If you get an ERROR LIGHT on, then you know you have a problem in your printer. If there are no ERROR LIGHTS on, then reach over and turn the printer off again. You will now have to refer to your USERS MANUAL/OWNERS MANUAL for available "Internal EpsonSelf-Tests" that can be ran on your model of printer. Normally, you would hold-in on the button that is listed in your USERS MANUAL/OWNERS MANUAL and then reach over and turn the power button on, as you normally would. The printer will normally print out an "Internal Epson Self-Test Copy" and the self-test copy should be correctly fed thru the printer...AS A GENERAL RULE: If the self-test page prints out correctly, then usually your printer is working normally. This does not mean your printer may not be dirty, or have another service related problem, or even a bad ribbon cartridge. It just means the printer is basically working normally as far as the internal tests go. You could run this self-test several times [just be sure], but usually if it works once it will do the same again. If your printer is working ok, then your problem could be in your PC. Again I'm sorry, but as I don't work on PC's, so I can't help you with those type of problems. You may need to get help from a Computer Technician, if you do determine that your possible problem may be in your PC or System...If the internal self-test does not print out normally, then you can assume the problem is in your printer. If the test fails, then it normally would indicate a possible problem in your printers "main board assembly" [PCB], "printhead assembly", or a related electrical hardware type problem...Good Luck!
Sep 07, 2009 | HP LaserJet 1020 Printer
Windows Home Basic 32 bit and HPC4380 printer setup wirelessly. Have printed ok in the past but now get blank or incomplete pages. Have installed latest Aug 2009 driver and have re-installed many times....
To isolate the exact cause of this issue please print a self test page and check whether the same issuse persists.
Print Self test page:
Please click here and follow the instructions to print a self test page.
If test page is not printed properly then clean cartridge contacts and nozzles.
If issue still persists then replace the cartridges.
Sep 05, 2009 | HP Office Equipment & Supplies
Proble with HP laserjet 3330
You will have to have the scanner assembly replaced. There were some problems with the earlier versions and they have seen been rectified. I have not had a single one come back in after replacing it.
Jun 01, 2008 | HP LaserJet 3330 All-In-One Printer
Printer bling ect
Dear friend this light blinging problem is with Print cartridge please check cartridge with Ok printer .
100% u r problem is solved ...
& at ones time Printer get all paper
this is a default printer tray alliment problem .so u take care that your paper bunch is no longer insetred in to printer just under pickup roller.
if problem is solved please Rate me ...
May 23, 2008 | HP DeskJet 3745 Printer
Not working properly
I'm having a similar problem. So far my solution has been to disconnect the 3330 from power for a longer period (> 30min.) and then switch it back on again. After the self-test everything appears to be ok again. I've got no idea why, but this seems to work (for now)
May 07, 2008 | HP LaserJet 3330 All-In-One Printer
Print out is to light
problem is your scanner assy
scanner assy create image to toner drum
scanner asyy contain 2 glass,prizom,rotate motor, and laser bim
pcb
clean scanner assy problem will sure solve
Feb 19, 2008 | HP LaserJet 5L Printer
HP LaserJet P3005dn Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
