Question about Samsung Digimax D53 Digital Camera
The camera will not power up even though it has fresh batteries
  • 6,826 Answers
Check polarity or direction of AA batteries in camera to see if they are reversed. Also, check to see if they are seated ok in the camera. Check to see if contacts are dirty.
Posted on Jul 03, 2010
My Nikon Coolpix L310 shuts off when I press the button to take a pic even though I just replaced the batteries
When this happens I always ASSUME batteries (power) Never assume the batteries are fresh. I know you do not like this answer but it is all I can say at this point.
Feb 07, 2017 | Nikon Cameras
My sony dsc-s500 camera wont turn on , even with fresh batteries. it doesnt even do anything but annoy me, not at all! please help!!
Clean battery terminals inside camera battery compartment, this model tends to get battery terminals clogged and causing no power up problem.
Aug 26, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
The main batter will not hold its charge when left in the camera.
After 12 months use camera batteries will not hold a true charge, but they can still be used for clocks, or remotes. Buy new ones. We all have the same problem.
Mar 08, 2009 | Sony Alpha DSLR-A100 Digital Camera
Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Feb 25, 2009 | Kodak EasyShare C613 Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Power up problem
Try resetting the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Panasonic's website and look for firmware updates. Download and install them.
But it also may be underpowered batteries. So make sure you're using the recommended battery types. I recommend using high energy batteries designed for digital photography. Varta is a good brand. They are usually sold in camera shops, are long lasting (because they are sold in small quantities) put out alot of energy.
And, even though you think you've put in fresh batteries, underpowered batteries are just as bad. At the very least, make sure you are using Alkalines. Even better, batteries with a higher mAh - like around 2500mAh would satisfy the higher power requirements of your camera.
Dec 13, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Camera will not power on with fresh batteries
Do you see a red light when you press the power button or is there no activity at all?
Feb 23, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Everything else works but will not take picture
Whilst there may be another fault, replacing the battery cover is a good start and you need to eliminate all possible causes.
These cameras also only reliably run on Lithium batteries.
I've seen many sets of fresh alkaline batts not work, even though they show full power.
Lithiums are more expensive, but they last much longer than several sets of alkalines, which ends up being far greater $ value and you are not constantly changing batts.
Worth a try.
Jan 27, 2007 | Kodak EasyShare CX7330 Digital Camera
Samsung Digimax D53 Digital Camera Logo
180 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
