Question about Toshiba 50HP82 50 in. Plasma Television
TV displays only "now booting" is there a module that can be replaced that will fix tv? And what is the module called (e.g. "z-board" or "x-board")
  • 2,335 Answers
I can help you with your Toshiba Plasma TV.
My first comment is that is your TV's boards are in good enough shape to display the 'now booting' message, then they may not need replacement. It is possible a Hard Reset of your TV will be enough to bring your picture back.
First, unplug your TV for a good five minutes and plug it back in.
Then, after plugging it back in, press and hold the POWER button on the set for 5 seconds to reset the TV.
My second comment relates to the model number of your set. I know it can be a challenge to find the correct model forum for posting here at FixYa. I notice that your post is under 50HP82, while I can find no reference to the 'now booting' phrase in the 50HP82 manual. However, the 50HP95 manual does mention that this message will be displayed upon startup until it can enter Standby mode. The more accurate your model information can be, the more specific our solutions will be.
I hope that helps.
___________________________________________
Download Toshiba 50HP95 Plasma TV Manual
Download Toshiba 50HP82 Plasma TV Manual
Posted on Jul 03, 2010
I am having problem with my lg tv 21 inches.problem is "no audio & video when i power on the tv.signal is there in tv,but no display.please help me
this is a problem with the controlling module on your main board and can only be fixed by replaceing the board i would advise having it sent back on warranty if it is under it but otherwise it will cost around 130 pounds sorry i hate giving bad news i run a repair service so i can garuntee this is the problem please make sure and make payment as soon as possible thank you
Jan 17, 2011 | LG Televison & Video
I have a dynex rf modulator that I am using in between the computer and the tv because the tv only has a coax connector. When everything is hooked up, the tv is on channel 4, the computer video only shows...
Have you been into the display options to choose how you would like to use your external display.
You should be able to change the settings by right clicking on the desktop and looking for display settings
Oct 07, 2010 | Computers & Internet
My toshiba 57" tv is always fuzzy looking and i do not know how to fix it. any suggestions?
This tv have a problems call CONVERGENCE,it dead.The tv convergence board have the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 16, 2010 | Toshiba 57H82 57" Rear Projection...
My tv has a aprx 3" wide black stripe on screen, the stripe is verticle and is always there with tv on. is it worth fixing? thanks
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} in most cases this will be a bad buffer module. this board is called other names but they all do the same work.but a cost will range around $500.00. in some cases it is the display itself and a cost would be more than you paid for the unit. but this is not common.
good luck...
May 24, 2010 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Powering up
Good day sir, hi, your plasma TV has a module called switching power supply board, this board accepts AC mains 110/220v and convert them to different voltage levels to power your plasma tv. If your TV isn't powering up, this board is the culprit. you need check the fuse of this board or replace this board if the fuse is good. A replacement board is hard to come by, call your dealer if there is warranty, use it. If the warranty has already lapse, inquire your problem to them about the service. thanks.
Nov 11, 2009 | Televison & Video
TV green light turns on. YOu could hear the audio out of the receiver which is connected to DirecTV. But, no video.
Hi, Look for bulging capasitors on the DM module board located to the left from the back of Tv and replace them. Should fix the problem or call a local Tv Repair Shop. Thanks.
Sep 22, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Blinking green light no pic or sound
Hi Stan,
the blinking green lights is usually called The Blinking Light of Death
There is nothing much else you can do.
The problem is some swollen capacitors on the 5v line keep the microprocessor from booting up (the 5v is supplied to the micro).
The repair should not be over $250 to replace those 4 capacitors on the DM board/module.
They had a huge run of these sets with bad caps.
You cant do a error test because the micro won't boot. I'm afraid your options here are limited to calling for service.
be aware you can kill you tv by trying DIY, but click here for your fix.
similar tv, same problem, I'd leave it up to a pro though.
- justasnwers.
more info on the indicators:
http://www.hdtvoice.com/voice/showthread.php?t=52010
http://www.techlore.com/forum/thread/19524/Mitsubishi-WD-62725-Status-Light/?page=10
hope this helps,
regards,
voodoo
Jul 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Lg plasma 42PC3D no picture with sound
I know you already replaced the board, this is for future searchers. If you heard a popping sound, then the picture went out, there is a 32 pin Sanyo module that goes bad on the board. That's probably what caused the fuse to blow. Replace the module, then replace the fuse. The module is less than half the cost of a used board. Since this was a popular model TV, there are lots of replacement boards on the used market.
Mar 15, 2008 | LG 42PC3D 42 in. Plasma Television
Rear Projection TV P52770EB
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Feb 29, 2008 | RCA P52926 52" Rear Projection Television
JVC32X776 NO PICTURE
it is call an video module circuit you need to mention the part number of the module and the model of the tv good luck.
Apr 27, 2007 | JVC LT-32X776 Television
Toshiba 50HP82 50 in. Plasma Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
