Question about 2wire (1000-000057-000) Modem
5.1V 1A adapter will not power up my 2-wire(4200-005000-000) Found a 2-Wire 5.1V 2 A adapter that will. Is this too risky?
    Brigadier General:
  • 10,406 Answers
First, check with your Internet Service Provider; if they provided the 2WIRE modem, they will replace it, "no questions asked", if they want to KEEP you as a customer.
Second, give the 2A adapter a try -- nothing can get "worse" than the current "broken" status.
Posted on Jul 03, 2010
  • 38 Answers
I agree with ikkenom.
Posted on Jul 26, 2010
My compresssor keeps tripping the breaker>
Loose wire in panel box or loose wire around compressor. any loose wire causes a high amp draw which blows the breaker. I've found wires that look good but are loose. Go right to the compressor outside and check there first. pull disconnect first and make sure there is no power. you either have a shorted compressor or loose wire. if you ohm out compressor with power off and disconnect the three wires you will get something like this....one wire to other wire 2 ohms... same wire to other wire 3 ohms... other two wires you should get 5 ohms...2+3=5 good compressor.they will add up to each other.
Sep 28, 2014 | Heating & Cooling
I have installed two diferent graphics card, #1 was MSI 5459 and #2 was a Nvidia GeForce 250. Bth ran fine afor a short period of tme #1 for a month an #2 for about 2 weeks. After these periods of time...
I don't find the MSI 5459 graphics card, William.
Am familiar with the Nvidia GeForce 250 GTS, though.
Using the GeForce GTS 250 as an example, the graphics card requires a 6-pin PCI-Express power cable, for additional power, along with the power it gets from the PCI-Express x16 slot it is in.
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
The unit is furnished with an adapter power cable, that converts 2 Molex power cables, (4-pin Peripheral power cables, actually), into 1 PCI-Express 6-pin power cable.
Note that the 6-pin PCI-Express power cable, has two Yellow wires in it.
Let's look at a 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note there is one Yellow wire, one Red wire, and two Black wires.
The Red wire is a 5 Volt wire, and not used by the adapter power cable.
The two Black wires are Ground wires, and only one is used by the adapter power cable.
The Yellow wire is a 12 Volt wire, and is used by the adapter power cable.
The 6-pin PCI-Express power cable requires TWO Yellow 12 Volt wires.
(And three Black Ground wires)
This means Two 4-pin Peripheral power cables MUST be used.
Failure to use two 4-pin Peripheral power cables, to that adapter power cable, means the GeForce GS 250 is NOT receiving enough power.
This will burn the connection at the graphics card, burn the adapter power cable connector, and burn the PCI-Express x16 slot it is sitting in.
Takes time, but will happen.
Could this be what you have done?
It also requires 150 Watts all by itself. You need more power for the rest of the computer.
(The 6-pin PCI-Express power cable is designed to provide up to 75 Watts of power. This means 75 Watts of power, also comes from the PCI-Express x16 slot, it is sitting in)
Nvidia GeForce GTS 250,
http://techreport.com/articles.x/16504
For additional questions post in a Comment.
Regards,
joecoolvette
May 20, 2012 | HEWLETT-PACKARD HEWLETT RECERTIFIED...
I have a BTC keyboard, Model #: 9000A. A wire became broken in the PS/2 male plug. I need a Schematic so I can solder on a new plug. I know this is a very old keyboard, but I like it and do not have the...
Unfortunately there is no color code for the cables in the PS2 connector. All the details that I can give you is that if this is the PS2
The pin #1 moves DATA.
The pin #2 is not connected or DATA2 (usually not connected)
The pin #3 is GND
The pin #4 is VCC for power (+5 VDC)
The pin #5 is CLK for Clock
The pin #6 is not connected or CLK2 (Usually not connected)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 18, 2010 | Computers & Internet
Can you tell me how to get a new power adapter for my Belkin usb network hub.
Best is to get an original replacement of course. But it does not have more than a transformer, four diodes and a capacitor, any spare adapter with the same or at the worst case +/-1V will do (higher voltages on your risk), and equal or higher output power (A). For example:
Original: 7.5V 1A
Suitable: 8V 1.5A, 7V 1.8A
Not suitable: 3V 300mA, 12V 1A.
Once you find one, just connect the power cord from the old adapter, OBSERVING + and -.
Nov 06, 2009 | Belkin USB Hub
How to run a CPU fan (12 V DC)[0.15 A] S8025M
The fan should have a red and black wire. You don't need the other one or two wires if there is (yellow/blue are for monitoring, if they are there).
The fan will take anywhere from 5V to 13V, so depending on how much noise you want you can change it.
As for the amperage, you want at least 1A. Most fans take 0.3A, but some powerful ones can take up to 0.6A. The quick easy route: Go with 12V and 1A., so 12W.
As for running them in parallel, sure you can. I've done it myself many times. Just match red with red and black with black, so that the endings are still just one black wire and one red wire. You can chain as many as you want, but add 1A for each fan.
Apr 09, 2009 | Computers & Internet
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
Apr 07, 2009 | T-Mobile MDA
Need line set size for goodman ck-36-1a
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Sep 26, 2008 | Goodman Heating & Cooling
Hp scanjet 5200c does not power on
check your adapter or power cable first.
Mar 20, 2008 | Office Equipment & Supplies
Compaq power supply HP212 (old)
If connector have two big brown wires (pins 1 and 11) and a small brown wire (pin 2). then short circuit the small brown wire with a big brown wire (pins 1 and 2).
Also short circuit the small black wire (pin 16) with a big black wire (pin 17).
Ps. The Power Supply needs a minimal load ex: 1A.
Dec 04, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
ASROCK 845 BIOS PROBLEM
Hi, This problem sounds more like a failing poewr supply than a bios problem. Can you use a multimeter? If so then check the voltage output from your power supply. The red wire = 6v+or-1v. The yellow wire= 12v+or- 1v. black is negative. If you are not sure then try a different power supply. Goodluck mistyman
Sep 14, 2007 | Asrock P4I45GV R5 Motherboard
2wire (1000-000057-000) Modem Logo
481 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
