Question about Mcintosh MC352 Amplifier
Panel lamps for Mcintosh MC352
Can anyone tell me the type and value of the panel lamps for the Mac MC352 ?
I'd like to get the replacement bulbs before the amp is disassembled.
Thanks in advance.
Ed
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
You can get an upgrade to LED light instead from
http://www.audioclassics.com/
This would be a great option.
Posted on Jul 27, 2010
I need to change lamps in McIntosh MC7205 Amplifier
First off before you do it is a specific bulb custom sized. I cannot stress enough how important it is to use the correct bulbs for this application. If you go the cheapy way it will COST in the end. There is a reason for it. I recently had one someone brought in that used the incorrect bulbs and burned the blue to a horrible brown and blue away from the face as well as melted the face a little. Spend the extra and get the bulbs from McIntosh It was a three hundred dollar repair job. You will save by getting the correct bulbs and doing it yourself. I hope this helps pointing the way to save lots of later frustration.
Sep 29, 2012 | Mcintosh MC7205 5-Channel Amplifier
Where and whats is involved in removing the bulb from a dell 4201c hdtv plasma 42"
If it is a flat panel plasma tv there is no lamp (bulb) in this type of set. Only rear projection LCD and DLPs have Lamps that need to be replaced.
Aug 11, 2011 | Dell W4201C 42 in. Plasma HDTV
Left channel doesnt produce sound as vu meter don't represent any output as well. Think perhaps the mono stereo switch could be the issue, seems like I was able to get channel running by flipping switch...
Hi
from your description it looks like the switch causing this problem
replace the switch might solve this problem unless its cause some short on the main circuit
if you want to fix he Amp let me know
ecrdn@yahoo.com
Jack
Oct 19, 2010 | Mcintosh MC352 Amplifier
Hi ! I have a Mc Intosh MC352 and my problem is that I have it hooked up with my B&W 802s. And i notice one side is louder than the other. I checked my Wires an everything seem s fine. What's the...
Swap the speakers around. If the sound stays on the same channel and doesn't move with the swap, then the amp has a fault on that channel. If it does move to the other side the speaker is the problem.
If it is an amp fault you can track it down using a insulated tool and the buzz test. You simple touch points on the good channel with the tool and in places it will buzz. You compare that by touching the same places you got a buzz (on the good channel) on the bad channel instead and if it doesn't buzz or it's weaker then you have located the problem.
You can also check the voltages with a meter in the same way. As the voltages should be the same on the two channels.
Aug 25, 2010 | Mcintosh MC352 Amplifier
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
Miniature dial panel bulbs for Onkyo TX-2500 Mk II
Chances are they are LED. Check with Radio Shack or online you can check www.1000bulbs.com Hope this helps
Sep 21, 2009 | Audio Players & Recorders
Imac g4 flat panel 1.0 gb power lamp replacement
this led indicate your mac is sleeping, don't panic
Jan 06, 2009 | Apple iMac G4 Desktop
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
Mcintosh MC352 Amplifier Logo
493 people viewed this question
Top Mcintosh Audio Players & Recorders Experts
sean tan
Level 1 Expert
 Grubhead
Grubhead
Jay Plesset
Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
