Question about Grohe Plumbing
I have a Grohe Europlus faucet . It's around 5 years old . It is leaking at the bottom where it connects with the surface of the granite . What do I ned to do
  • 10,319 Answers
Nice faucet. The cause of leak can be:
1. Leaking Hose
2. Loose handle
3. Worn out washer between handle and hose
4. O-rings inside the column
5. Loose water supply lines at the body connection
First make sure the handle is firmly screwed in into the hose socket with good washer between the handle and seat of the hose. If that connection leaks then it leaks inside the body of the faucet and down to your cabinet. 50% of time this is the problem.
Due to the age of the faucet I would also suspect the O-rings inside the column. When you install new O-rings than you have to apply the grease so you don't clip them while installing column collar.
Let me know how you did
Posted on Jul 03, 2010
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
The base of the faucet which fastens to the top of the granite is loose and moves around. Is there a nut under the faucet that tightens to keep it firm to the granite? How do I fix this?
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
Oct 31, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a brand new Europlus faucet with hardly any water flow. I had the first Euro faucet with good flow. Why is the water flow so low on a brand new faucet.
when you installed did any teflon tape or debris get inside? you can remove and reverse flush with hose and it may clear the blockage
Jul 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a Grohe Europlus Kitchen faucet. The base
there is a couple of plates with a little screw in the center that tightens up the plate got to tighten it up
Jun 23, 2009 | Plumbing
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Plumbing Logo
140 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
